Question about Ovens
How do I set Miele h 809 oven clock - Ovens
e-Guru
  • 3917 Answers
SOURCE: Jenn Air oven model #
There are a couple of steps you can do. First unplug the unit and check the wiring at the back. Next disconnect/reconnect the connectors at the control board. Check them for any visible problems.P4 on the board goes to the elements perhaps it is loose or has pulled something else loose. I think this is a long shot as the board is working and as far as I know there is not a separate power input to the board that just runs the display. For replacement of the part you can check the bellow link:
Replacement parts for JENN-AIR JER8885QCS Range - F/s Std Ele
Posted on Nov 29, 2010
  • 354 Answers
SOURCE: how do you set the
Just play with it or go to the manual or support site online
Posted on Feb 15, 2011
amsmith525
  • 99 Answers
SOURCE: How do I set the
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Posted on Mar 15, 2011
bilkerarslan
  • 49 Answers
SOURCE: How do I replace the light bulb behind the top left two control knobs on the front of Miele oven H 809? Picture shows top left two unlit - should be like the two to the right.
Need to see if whole panel can be removed else you must be able to get them individually out by using something like screwdriver, of course unless the company that produces the oven doesn't want you to open it
Posted on Nov 05, 2012
  • 3 Answers
SOURCE: HOW TO SET CLOCK ON MIELE H806 OVEN
On the control panel: Beneath the label "Cooking Time," press the "Duration" and "End" buttons simultaneously and hold using your fingers on your left hand. An arrow will display above each button.
Using your other hand, rotate the knob to the left of the panel to adjust/set the time one direction or the other. Once set to the appropriate time HH:MM, release your fingers from the "Duration" and "End" buttons.
The time is set.
Posted on Nov 20, 2012
Nov 04, 2012 | Ovens
How do I set the clock on the Miele oven?
Mar 15, 2011 | Miele Novotronic H350-2B Electric Single...
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Miele H 5240 B CS oven Purchased E & S Trading, Ashburton, 1 October, 2010 When I press the arrows and the OKin between, about 70% of the time nothing happens. Sometimes wetting my fingers seems...
Hi the is a two year g/tee on all Miele appliances. I would contact Miele and book a service call. The appliance most likely requires new clock. Modified clocks are available which allow you to change setting via control knobs rather than keypad.
Jan 16, 2011 | Miele Novotronic H350-2B Electric Single...
Need to set time on Miele Oven H398B2?
Turn the upper oven on. Hit 'MORE' once or twice until you see 'SETTINGS' touch that and navigate to 'CLOCK' Once there, you can enter the time using the keypad. Hit 'OK' to exit. You can download the manual from the Miele website or request a printed version from them.
Nov 02, 2009 | Miele H398BP2 / H398B2 Electric Double...
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
Dec 30, 2007 | Miele Novotronic H350-2B Electric Single...
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Ovens Logo
78 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
