Question about Hammacher Schlemmer Low Impact Foldaway Strider
My low impact strider does not sit properly on the floor...it falls over to right or to left when I try to use it
Where is the yaw sensor located on a 2008 Pontiac Torrent?
yaw-xozrttqlr3qpoa0t2tmccx0o-1-0.png 1 - Floor Panel
2 - Console
3 - Yaw Rate and Lateral Acceleration Sensor
4 - Seat Belt Pretensioner - Right
5 - Inflatable Restraint Side Impact Sensor (SIS) - Right (ASF)
6 - Rollover Sensor (ASF)
7 - Inflatable Restraint Sensing and Diagnostic Module (SDM)
8 - Seat Belt Pretensioner - Left
9 - Inflatable Restraint Side Impact Sensor (SIS) - Left (ASF)
Apr 16, 2017 | Pontiac Cars & Trucks
Top door will not close by itself on fridge
Sounds like the floor of the house.. might be your problem..Try moving the fridge out of its position and build a small flat platform in that place and level it, then place your fridge on top of it..just in case u may need a little final adjustment get those small wooden wedge shims when you get your wood..they sell them at lowes or Most lumber yards....that should take care of the leveling..good luck..good luck
Nov 28, 2014 | Electrolux Refrigerators
Does these scooters fall over at all
Mandi all scooters can fall over but especially the 3 wheel ones. Hope this helps you
Sep 21, 2010 | Electric Strider Midi 3 Wheel Mobility...
Keeps falling over due to bent leg. Any ideas on how to fix?
Depending on which leg is bent, you should be able to move all legs so he sits properly in a sitting position on the floor. If this fails then lie him down as the legs can be moved while he is turned off.
Jun 26, 2010 | Tiger Electronics FurReal My Lovin' Pup
Anybody can help?
They torque them on there so it won't fall off under hammer use, they never know what you will be doing so they don't take chances. You will have a tough time getting that thing off, why do you want it off anyway?
Feb 21, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Nikon S220 white LCD screen display
Sorry, but 40 centimeters is a lot for a camera that isn't shockproof.
Sep 28, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Stairmaster 4600pt pedal falls without warning
i have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Apr 14, 2009 | Stairmaster 4600PT Stepper
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
Hammacher Schlemmer Low Impact Foldaway Strider Logo
43 people viewed this question
Top Hammacher Schlemmer Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Hammacher Schlemmer Exercise and Fitnes Expert? Answer questions, earn points and help others
