Question about KitchenAid KUDS30IXWH Builtin Dishwasher
KUDS30IXWH no response when touching the cycle options
My 2yr old washer has LCD screen which seems to be only responsive in one area of screen. beyond frustrating! Troubleshooting/repair cost experience appreciated!
http://www.ebay.co.uk/itm/New-Samsung-Dryer-Assy-PCB-Sub-LCD-Control-Board-DC92-01100A-for-WF457ARGSGR-/391328349713?hash=item5b1cfcbe11:g:h4EAAOSwp5JWVKyU
Oct 07, 2015 | Samsung WF457ARGS 27" Front-Load Washer...
Upper rack disengages from the arms
Lift higher at the front. You should be able to put back the bearings into the rails.
Dec 24, 2013 | KitchenAid KUDS30IXWH Builtin Dishwasher
Top rack not washing
Obstructed washer arm or stuck bottom extender pipe
Jun 13, 2012 | KitchenAid KUDS30IXWH Builtin Dishwasher
Touch screen phone alingment
My HTC allows my to re-set this in the Windows Mobile Settings>System>Screen.This option will Align the screen by touching the cross hair as it moves around.It's pretty much self explained.
Dec 25, 2011 | HTC Touch P3450 Smartphone
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
I want to adjust the sensitivity of my touch pad, but I cannot find any software that allows me to do so. The only pointer software and driver hardware apparent in control panel is for a mouse.
those mouse options, speed, buttons, tapping to click - should still apply to the touch pad - see if Have a look at a TAB called Pointer Options - that will enable you to slow and speed up the touch pad response
Apr 22, 2010 | HP Pavilion dv2742se Notebook
One of two one touch control does'nt work
RESET TO FACTORY DEFAULTS(USE THE MASTER PANEL)THEN REPROGRAM YOU'R OPTIONS!!!!!!!!!!!!
Oct 23, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
KitchenAid KUDS30IXWH Builtin Dishwasher Logo
52 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
