Question about Vizio VU42L 42 in. LCD TV
55"Visio TV won't turn on but logo light stays orange
SOURCE: Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Posted on Nov 03, 2008
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
Sebin
  • 712 Answers
SOURCE: Model VS42LFHDTV10A. The TV is
This may be the problem of relay switches. It can be replaced to eliminate such errors.
Posted on Sep 11, 2010
eagle338
  • 4889 Answers
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
Posted on Dec 29, 2010
  • 302 Answers
SOURCE: Visio model sv320svt will not
Hi after the logo flashes does it turn off completly or do you see the power light still on or any other lights?
Posted on Jun 02, 2011
How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
Jan 31, 2018 | Vizio Televison & Video
Vizio logo blinks orange/white for a minute then stops blinking. TV never comes on.
If there was a power surge, a power supply component may have failed.
Jul 01, 2014 | Vizio M550NV 55 in LCD HDTV
Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 22, 2011 | Vizio E550VL 55 in. LCD HDTV
Visio model sv320svt will not turn on....visio logo in front flashes on and off..what could it be?
Jun 02, 2011 | Vizio SV320XVT 32 in. TV
I have a Visio 47 in LCD HDTV Model GV471 FHD that just went dark in the middle of a show we were watching. The remote has no control but does light up all buttons then goes off with no function. I...
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Vizio VO47L 47 in. LCD TV
Vizio VU42L 42 in. LCD TV Logo
27 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
