95% of what number is 38 - Computers & Internet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
40.
Posted on May 24, 2014
38 s&w serial number 319926 year
Not easy on Smith and Wesson. See the link for some tips.
38 revolver serial numbers Google Search
Nov 06, 2017 | Sport & Outdoor - Others
I have a true cooler for bottles and i dont knowhowto make it cooler
If it is a number thermostat, first check your box temp., then change the dial 1 number and check temp. in about 2-3 hours and see which direction it goes. Usually thermostats with numbers causes the temp to change very slowly so take your time and you can figure it out.
Sep 09, 2017 | True TD-95-38-LT Beverage Cooler
Im trying to know what year model is this smith and wesson 5 rds 38 cal double action with serial # 137623
Why not post something helpful, like a model number? Or the actual caliber? .38s&w? .38 spl?
.38 double action?
.38 safety hammerless?
.38 spl hand ejector m&p?
Aug 16, 2017 | Sport & Outdoor - Others
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
Can't install Alley 19 on XP.Says not enough hd space (has 31.9 Gbites freespace)Install only takes 38 mbites
Run in windows 95 compatability mode. Click on My Computer->right click on the cd drive->open-right click on setup->properties->compatability tab->choose windows 95 then run it.
May 12, 2012 | Masque Publishing Alley 19 Bowling
Yes I have a True 95 38 Beverage cooler and I bought it new 4 years ago , I have used it for 3 and 1 year it just sat not running , well I plugged it in the other day and it is only blowing warm inside and...
Could be many things... A bad thermostat, bad compressor, bad compressor start relay, refrigerant leak, moisture in the system, or even a blocked capillary tube. You would need a lot more information... mostly only the kind a technician can get by getting his hands on it. Sorry.
Sep 11, 2010 | True TD-95-38-LT Beverage Cooler
1995 4.0 4x4 jeep grand Cherokee Laredo blinking check engine code 38-55
Sorry I can't find a code 38 for '95 Jeeps in any of the data bases.
55 - End of codes
Jun 05, 2010 | 1995 Jeep Grand Cherokee
Replacement blades parts number
95-003 IS THE MULCHER BLADE 95-047 IS THE HIGH LIFT BLADE HOPE THIS HELPS YA
Feb 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
How does this td 95-38 unit drain?
When working correctly the drainage runs out of the evaporator section in a tube that ends in a pan at the base of the compressor. Remove the grill covering compressor section and you should see the edge of the pan under the compressor.
Nov 07, 2009 | True TD-95-38-LT Beverage Cooler
Sliding door replacement parts
I go to Home Depot to get their aluminum 'L' bracket (3 ft or 4 ft lengths, etc by 3/8th or 1/2 inch), usually by their screw and nail aisle. Depending on whether the rail you're fixing is on the box's outside frame edge or an separating inner edge, you'll need to turn the 'L' either up or down so that the screws to attach it have something to bite into. I also add a line of Gorilla glue to the aluminum and wet the edge it need to attach to for extra strength.
Jun 07, 2008 | True TD-95-38-LT Beverage Cooler
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
