Question about Apple Ipad 3 16gb Wi-fi Only Md328ll/a 9.7" White Latest Model 2012 Ipad3 16gb
Skype won't ring on. Incoming calls
Your question area stinks. I told you my question. I doubt if you have an answer as to why my IPAD phone won't ring on Skype on incoming calls!!!!!!,I need to know why!!!!
penguinorama
  • 53 Answers
SOURCE: iphone wont ring
Did you check to make sure that the "mute" switch on the left side of the iPhone is turned off (if you see an orange dot, it means mute is turned on). It may not be vibrating either because in main Settings - Sound - you haven't turned on "Vibrate" when on Mute.
I thought my iPhone was broken until someone pointed out this to me.
Posted on May 24, 2008
Nova_1
  • 196 Answers
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Posted on Sep 07, 2008
SOURCE: Intermittently my iPhone does not ring and incoming calls get forwarded.
incoming call not come in myiphone want solution
Posted on Oct 14, 2009
  • 16 Answers
SOURCE: my iphone won't ring with incoming calls. I have
The only thing i would check is the switch on the side. Make sure its not sticking, or accidentally switched it... If its messed up, im sure Apple would replace yours! :)
Posted on Jan 31, 2010
  • 9 Answers
SOURCE: phone will not ring on incoming calls
Your phone might be set to silent. On the upper left hand side of the iPhone, there is a little switch. Switch it on/off to silence or set the sound of the ringer. If the problem persists go to Settings > Sound Settings > Ringers & Alerts
Posted on Jul 01, 2011
Testimonial: "thanks thats it !!!!!"
My incomingcall not ring straight to voicemail and iPad ringing why?
Verify that "Do not disturb" is off otherwise all your incoming calls will be forwarded to your voicemail.
Your iPad is ringing because iCloud has connected both. To disable this on your iPad settings go to iCloud and disable that.
Dec 07, 2014 | Apple iPhone Cell Phones
I cant answer viber calls on my samsung tablet why?
Are you using Sprint? They stink! I often do not hear the ring tones and only the message tones after they have called.
Mar 12, 2014 | Samsung Galaxy Tab Tablet PC
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
How to prevent HP 3380 All in One Printer answering voice calls
If you have call waiting on your phone service you can call your phone company and get "personal ring" service. It will cost a couple of dollars extra a month, but they will assign you another phone number and it will have a different ring style to it. Then you can set the ring type to the type of ring they assign you.
May 31, 2008 | HP LaserJet 3380 All-In-One Printer
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
Apple Ipad 3 16gb Wi-fi Only Md328ll/a 9.7" White Latest Model 2012 Ipad3 16gb Logo
80 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
