Question about Ricoh Aficio SP 3200SF Multifunction All-in-One Monochrome Network Laser Printer, 003127MIU
3200sf fuser open heat error replace fuser
2 Suggested Answers
  • 903 Answers
SOURCE: ricoh aficio sp 3200sf fuser door open error
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Posted on Jun 19, 2010
Open heat error
Open heat error is caused by a bad fuser. Replace the fuser assembly.
Jan 20, 2014 | Xerox Phaser 3200MFP/N Laser Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Printer is showing Open Heat Error & it is not getting solved
Open Heat Errors on the Samsung 4200 are caused by an interuption in powerflow thru the fuser unit. This is caused by one of two things. 1) The Power supply board is not putting out enough power to the fuser unit. 2) The fuser unit has a bad heat bulb or thermister. You can not really check these effectivly without having either replacements on hand or the full tech sheets and a multimeter. I am sorry to say buying a new printer or a replacement fuser unit will be your best bet.
Aug 30, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Ricoh aficio sp 3200sf fuser door open error getting "fuser door open" message. opened and reclosed fuser door to make sure fuser door was closed. restarted printer. still get same message. what can i do...
Jun 16, 2010 | Ricoh Multifunctional SP 3200SF...
Open heat error in my printer model SCX-4521F
open heat error sounds like the fuser lamp is blown. The fuser lamp is inside the hot roller at the back which melts the toner onto the page. It is not really a user serviceable part, you would need someone qualified to repair/replace the fuser.
Apr 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How do I repair an "open heat error"?
I'm sure it's not the answer you're looking for but the "Open Heat" error is related to the printer's fuser, switch mode power supply or temperature control thermistor. More than likely it's the fuser which needs replacing and you'd need to contact Dell for a replacement. If you google for "1600n fuser" you'll also come up with several retailers with fusers in the $80 range as opposed to Dell's $140+.
Jan 21, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1815dn error code "open heat error?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 29, 2009 | Dell 1815dn All-In-One Laser Printer
Open heat error
Most "Open Heat Error" messages are caused by a bad fuser. Order a new fuser from Dell.
May 22, 2008 | Dell 1600n All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Ricoh Aficio SP 3200SF Multifunction All-in-One Monochrome Network Laser Printer, 003127MIU Logo
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
