Question about Watches
Taking links out of my selco geneve watch
Need to adjust the band it is too big
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
  • 77 Answers
SOURCE: Adjusting Band Size on a Movado Amorosa Watch
there are little pins holding them in place pop them ou and add or delete couple links.
Posted on Feb 11, 2008
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
SOURCE: Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Posted on Nov 27, 2008
escapement
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
I just purchased a WR 50M Timex watch with a metal band with a clasp. Of course, the band is too big. There are tiny, tiny screws (almost to small to see) that apparently need to be removed to take out...
These watches are designed so that "regular" people can't adjust them. My advice (if you want to wear it) is to take it to a jeweler and spend the 20 bucks. If not, you should take it back and find one that fits. Target takes them back without a receipt - especially if you just want to exchange it.
Jan 05, 2011 | Timex 27191 Wristwatch
Got this watch for xmas, nice. the band is too big. how do i adjust the metal band?
u can have ur watch to the watch shop they may make it short fitting on ur hand
Jan 04, 2011 | Invicta 100 Meter Sport Diver Quartz...
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do i remove a link from the watch band?
hi friend,
step 1
Measure the watch band's length. Every wrist size is different, and there's no need to remove all of the links when you may only need to remove one or two. Putting the watch around your wrist and pinching each link around it to see how much room you need gives the jewelry wearer a reasonable estimate.
  • Step 258782_65x95_aspect.jpg Open the watch near the link you want to remove. Link watches have several openings, so even if you open the wrong clasp, it can always be reattached.
  • Step 358783_65x95_aspect.jpg Flick the tip of your fingernail inside the clasp to open the extra links. Continue doing so until you have removed all of the links that are too big for your wrist. If you have short fingernails, try using tweezers or anything with a sharp edge that can easily unfasten a link. New watches tend to be very stiff, so it may take a little nudging, but the links come off. It will be obvious which ones come off and which ones don't by looking at the back of the watch band. The links that come off have a claw on the tip of each one and sometimes have the brand name on top of it.
  • Step 458784_65x95_aspect.jpg Put the extra links in a safe place. There may come a time that you either let someone else borrow the watch or your wrist swells and you need these links again.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • If you can't get the links to open, visit a jewelry repair store. Workers there may be willing to help you adjust your watch for free. If you bought the watch from a retail store, the jewelry counter is usually required to adjust your watch for no additional cost.
    hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Kenneth Cole Reaction KC3367 Wrist Watch...
    How to make a relic watch bracelet a little smaller?
    No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
    Sep 18, 2009 | Relic 0504648FA
    Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
    You can tap out the pins in the band with a small punch. a ground off needle may do it
    Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
    Adjust ladies citizen watch metal link band
    If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
    Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    How do I adjust my timex wr 30m watch stretch band?
    It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
    http://www.watchmaterial.com/How_to_size_a_watch_band.asp
    Feb 13, 2008 | Watches
    Watches Logo
    409 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
