Question about Bowflex TreadClimber TC5
Bowflex treadclimber seems really stiff and cannot walk upright without holding bar
I cannot walk more than 5 minutes and have to hold onto the bar to keep my back straight. I have been a very experienced treadmill walker and never had this problem even when upping the incline. I am wondering if we failed to loosen something - we have it set at the minimum level - or does it need oiling? thanks!
rockfixya
  • 679 Answers
SOURCE: Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Posted on Jan 30, 2009
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
SOURCE: bowflex treadmill series 7 saying safe out
I had the same problem, however the treadmill remained in 'safe out' status even when the Safety pull pin was correctly inserted.
The cause of my fault was that one of the kids decided to insert a wrist watch into the round hole located on the control panel's lower cover. In doing so this unplugged the cable conector for the magnetic switch which operates the 'safe out' function, from the main circuit board. The repair was quick and easy, i turned the power off, removed the bottom cover from the control panel and simply plugged the magnetic switch back into the main circuit board and all was back to normal.
Posted on Dec 21, 2009
  • 679 Answers
SOURCE: my bowflex treadclimber starts for abut 3sec then
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Posted on Jan 22, 2011
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
Treadclimber stiff treadles
When you are in need of step two upwards, you'll find it together with the Bowflex TreadClimber Thread count 4000, with exactly the same dimensions not to mention measures 1800. The actual velocities start around .Five in order to Several.3 miles per hour. You possibly can course performance, effort, gap, calories burned, calories from fat each and absolute procedures, and you may be able to get pleasure from a strong ergonomic desk games console. You can find parts with respect to drinking water together with magazines and catalogs and it also consists of a a few 12 months service contract.
Apr 30, 2012 | Bowflex Treadclimber
I have received two cables that need to be replaced on my machine (nautilus treadclimber 5000) one is the I/O cable 8 Pin 75", Rt. Upright and the other is I/O Cable 8 Pin 42" Upright MCB. How...
The first one, "I/O cable 8 Pin 75", Rt. Upright", runs inside the right side upright tube from the handlebar to the base of the machine. The machine will have to be partially disassembled using the original assembly instructions in reverse to access this cable.
The second cable, "I/O Cable 8 Pin 42" Upright MCB", runs from the base of the right side upright back to the Motor Control Board. If you tip the machine carefully onto it's left side with the side plastics removed you can see this cable.
Jul 16, 2011 | Bowflex TC1000 Treadclimber
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
I hope this helps u
Jan 29, 2009 | Bowflex Treadclimber
Bowflex Treadclimber tc 1000 turning off
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
Bowflex TreadClimber TC5 Logo
82 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
