Question about Sony Televison & Video
6 red blinks on my SONY KDL50EX645 tv
I do see 6 red blinks on my Sony TV KDL50EX645....called up Sony and they told me that GE50 power supply board has to be replaced....any suggestions on this
eoddeputy1
  • 4 Answers
SOURCE: sony KDFE60A20 TV turns off and on with Red light blinking 5 times
Same problem here. 5 blinks is video related. I've been told to clean the screen by the lamp, as they could be clogged and causing it to over heat. Going to give thet a try first. I'll post what happens...
Posted on Oct 13, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
welcomejee
  • 10594 Answers
SOURCE: No picture or sound. Red light
Just a correction, it is not necessary that 4 times red light blinking always shows inverter board problem.
It depends on chassis/ model number of Sony bravia tv to what is error code of 4 blinks as it would be mentioned service manual.
I'm Sony tech and can help you, let me know model number written at back of tv to provide you exact info about 4 times red light blinking.
Thanks.
Posted on Aug 18, 2010
  • 4 Answers
SOURCE: Red Power Light Blinking 6 Times
THIS IS HOW I FIX MY SONY TV WITH FIVE BLINKING RED POWER LIGHT.
PULL OUT LAMP - FIND THE INSTRUCTION ON LINE (SONY WEBSITE OR YOUTUBE) EASY
THERE ARE TWO METAL CONNECTION TABS (on top of the lamp) ON THE LAMP. CLEAN THESE TWO METAL FLAT TABS. THESE two tabs MAKE CONNECTION TO THE THERMAL FUSE. IF IT IS DIRTY IT WILL NOT MAKE CONNECTION to the fuse.
CLEAN YOU'RE LAMP WITH A VACUUM. GET ALL DUST OUT.. CLEAN OUT THE TV...THE FAN SUCKS IN DIRT. THIS WILL FIX many ISSUEs. like over heating! dog hair, dust, gets sucked inside the TV by the FAN....hmmmm
ALSO DO THIS TO ALL YOU'RE ELECTRONICS THAT HAS A FAN.
(I FEEL ALL FANS ON ELECTRONICS SHOULD BE REVERSED) but i am sure there is a stupid reason that they want the fan to **** air inside the electronics. Like hmm
THIS cleaning SHOULD BE DONE EVERY 6 MONTH
Posted on Dec 23, 2010
peasterday40
  • 7 Answers
SOURCE: Light blinks red twice every 5 or so seconds on sony 24in 3d display. Anyone have or know the problem here?
same basic thing happened on my 50 in Hitachi plasma...I removed the back cover and found two capacitors on my power supply swelled...and two chips on one display board burned.Hatachi doesnt make the tv anymore and the parts were going to cost me almost what the tv did new...so...I sold it for parts on ebay...check all the boards for tell tale signs of damage...
Posted on Jul 04, 2012
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Sony bravia 50" red light blinks 6 times.
One thing you can try is to remove all cords attached to the tv including the power cord. wait a few minutes( maybe say a short prayer) then plug the power cord back in and try turning on the tv if it powers up. it maybe a short in one of the units that were plugged into the tv. If it still does not work it maybe a circuit board problem. Sony Bravias have been plagued with a lot of circuit board issues. type in Bravia problems on any search engine and you will see what I mean. You may be able to get it repaired but you best course of action is to buy a different tv. a Vizio or Samsung or anything but a Sony
Dec 30, 2013 | Sony BRAVIA KDL50EX645 50 Inch 1080p...
Red blinking standby on my sony tv
That problem is cause of faulty power supply board..
look at the capacitors if bulged then try to replace it..
Watch this video to learn more about capacitors:
If you have soldering skills its better to buy a new power supply board online...
Feb 03, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony kv34hs420 shut off itself
Hi:
If you count the number of error blinks when it shuts this will let you know the error code you are having. If the red led blinks say 6 to 7 times after shutdown then pauses and does it all over again there is a problem with the deflection board or D Boardas sony calls it, It is usually related to the two Power supply regulators IC's on the D-board.
Nov 09, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
Jul 13, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
6 blinking red lights
You still have your guessed problem. 6 blinks means Low B+ error (power supply). This can be caused by an open thermal fuse, loading by another circuit board, or the power supply itself.
Apr 13, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a code of 6 red flashes on my KDS E50-A10 Sony TV. I was told to replace the lamp and I have just done that, but I still have 6 flasing re light code and no picture. any idea what's next?
6 times red light blink shows error in power supply (GT) board because of no 12 volts output for some reason.
Replace GT board to fix the problem.
Let me know if you need GT board part number info.
Thanks.
Dec 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
