Question about Sharp UX 300 Plain Paper Thermal transfer Fax
How do I clear the paper jam notice on a Sharp UX330L when no paper is jammed?
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
SOURCE: clearing an error
You need to push the 'stop' button and wait for the fax to check itself for jammed paper.  Once this is done the faxes in memory will start printing again.
I hate this fax, this happens all the time on my machine, plus the paper will not feed properly unless I physically force it down which often leads to paper jams.  Which is how I know how to clear it.
Posted on Jul 23, 2008
marsrover
  • 682 Answers
SOURCE: Document jammed
in entry slots please check of any foreign object droped inside(like pins-small pieces of torn paper)-check also proper actuation of paper detecting micro switches and its lever(not broken)-move the lever with your hand and confirm it is move freely motion-and make cleaning to this area with air cleaner or soft tissue cloths.
Posted on Jul 27, 2008
SOURCE: sharp uxb700 document jammed appears
If you lift up the panel and look underneath there are two black plastic "levers" one to the right and one to the bottom of the black roller. The larger one on the right was stuck. When I pushed on it and it popped up the "document jammed" message disappeared.
Posted on Feb 19, 2009
  • 13433 Answers
SOURCE: paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
How can solve error H5 in sharp 5516s?
P * C * 14
Oct 04, 2014 | Office Equipment & Supplies
H5-01 without technician assistance
H5-01 means repeated paper jams on the Sharp photocopiers. Once the paper jam is cleared properly, you need to clear the error condition. Put it in 'Copy' mode. Press on the keypad: Related Groups. Printers, Copiers, Scanners &
Jul 14, 2014 | Sharp AR-BC260 Color Copier
How do I clear a paper jam in my Sharp EL-2630PIII adding machine?
My paper is stuck and jammed in the feeder. I cant add new paper because of the jam. The new paper crinkles up as it feeds. Is there a way to remove the jam of paper that's stuck inside ?
Jun 13, 2014 | Sharp EL-2630P Calculator
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Sharp UX 300 Plain Paper Thermal transfer Fax Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
