Question about KitchenAid Dishwashers
Kenmore Elite dishwasher 630.16309400, won't advance through wash cycle
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 10865 Answers
SOURCE: kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Posted on Apr 19, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 70 Answers
SOURCE: My Kenmore Elite dishwasher makes a buzzing noise
the possible causes.it could be some hard debris near the chopper blade inside the pump or some times water seal on the pump goes bad and water leaks into the motor bearing/rusting it and starts grinding noise.open the pump from inside and reach the choper blade and look for any hard debris.if find nothing then motor assly needs to be chgd.
Posted on Aug 18, 2009
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
