Question about Pool & Spa
Arctic spa error code ppr - Pool & Spa
3 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
SOURCE: 2001 arctic spa is showing error code FLO
FLO is for not enough water flow
This is a filter issue or pump issue. Remove filters and see if it goes away. If it does get some new filters here: http://www.hottubworks.com/
If it does not go away call us and we will walk you through trouble shooting. Most likely a circ pump if not filters.
Posted on Oct 26, 2012
Oct 14, 2012 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Arctic spa is set at 104 but will only heat to 93
no error message? likely the heater has failed. Its an easy fix. You can request service directly on the Arctic Spas corporate website, www.arcticspas.com
Dec 16, 2010 | Home
Error code PIER on arctic spa. What does this mean??
There is no such code. PRR means a problem with the temp sensor.
PRH means a problem with the high limit
Nov 20, 2010 | Arctic Above Ground Rugged Mesh Winter...
I have a 2003 Arctic spa and have changed the heater. I have a HL sensor error on the panel but the tub is cold?
HL usually means that the heater is working and there is no water passing through it, do you get a flo error message before the HL,I had the same problem, mine was the flo switch
Oct 08, 2010 | Pool & Spa
My printer keeps telling me the ppr is jammed
There is a sensor flag either stuck or sticking and it is causing it to give a false jam error
Feb 10, 2009 | Canon PIXMA iP1300 Printer
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
