I cannot get continuity to work when I touch the leads together. I replace the batteries and still not working
SOURCE: no beep on continuity mod
Needs new buzzer disc, or maybe buzzer disc fell out of its place and just repositioning it fixes the problem - this is the likely cause of your problem.Contact local Fluke authorised service centre or Fluke directly if you are in US and ask them for Audio Transducer (Part Number: 2041050). it should not be more than couple of dollars.
Sounds like you have and open limit switch trace the wires from the gas valve one will go straight to the terminal board the other one will go through all the safety limits take an ohm meter (an ohm meter beeps or lights up when you touch the leads together showing a direct connection also called continuity) and check each limit switch by touching one of the meters leads to one wire on the switch and the other meters lead to the other wire on the switch if no continuity is there your switch is open some switch's have little reset buttons on them. Find the open switch and reset or replace.
