Question about Sansui Televison & Video
Sansui tv wont turn on but the red light is on
19 inches
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: my sansui 19 in lcd tv is not receiving signal from my dell compu
check the cable,check the graphics adapter is seated in ur system perfectly,check if any boot sirens came from ur cpu when starting the system.
Posted on Jan 17, 2009
zabolyx
  • 38 Answers
SOURCE: TV Wont turn on blue flashing light when plugged in
Your TV has most likely come into contact with a static discharge. Don't fret it might not be damaged.
My Phillips TV I had came with a built in defense of sorts. The system will shut down and flash the power light as a warning.
Unplug you tv for 5 - 10 minutes and then plug it back in. Give it another try.
Posted on Apr 01, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a dynex 19 inch tv that wont turn on can
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Dynex+DX-LCD19-09+
Please post back what you find
Posted on Dec 18, 2009
  • 8457 Answers
SOURCE: 19 inch lg flat screen tv wont turn on
Power Supply board is dead.Tries Websites Shopjimmy.com,Ebay.com.Buy a refurbish power supply board for the replacement.
Posted on Mar 24, 2010
How many inches in 19 mm
One mm is 0.0393701 inches. 19 mm is 3/4 of an inch. There is a conversion table you can use:
http://www.metric-conversions.org/length/millimeters-to-inches-table.htm
Mar 07, 2015 | Cars & Trucks
Trying to get the seatslower to ground.have power seats&235-50-19 tires for my disabled spouse,2013 equinox ,ltz, awd
Two inch dia. change will only lower the vehicle one inch. Hardly seems worth the effort.
Oct 18, 2014 | Cars & Trucks
Sansui operating manual
http://www.schematicsunlimited.com/s/sansui
Aug 13, 2014 | Sansui Televison & Video
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
My sansui t.v wont turn on
1= you have problem with the main switch for open or faulty, test with VOM
2=check the power supply: a)filter b= coil c= trafo d=diode e=rectifier f= fuse or c.breaker repair or replace
3= HV rectifier for output horizontal +125 vdc +Flyback test
4= vertical output +80Vdc
5=12vdc for color
6= other circuite 12vdc.
see the block diagram
God bless you
Aug 03, 2012 | Sansui TVM1916 19" TV
MY tv is not getting turned on Manually/ Remotely..!
First if now total dead it has a fuse inside to look at.
Jun 14, 2012 | Venturer 19 inch flat screen TV
What is a good height for an office chair?
office chairs range from 14.5 inches all the way up to 23inches. A good height is around 19inches. Usually chairs have a lever thatallows you to raise and lower the height as you wish.
May 29, 2012 | Furniture
Televison & Video Logo
87 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
