Question about Waring WFG150 Panini Press Tostato Perfetto
Burning food Gets too hot
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
The plug and wire near the plug on my Rowenta iron gets very hot when I use it
The plug is not making proper contact in the wall socket. Clean the pins with steel wool or pot scourer. Do not use water. If you are using a double adapter remove it as it could be the cause of the poor contact. If the problem persist, try a different wall socket and get a qualified person to fix the faulty wall socket.
Apr 03, 2013 | Rowenta DG5030 Iron
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
I have a Tefal Pro Express Turbo iron (purchased in 2005). In the past 2 days the steam is constantly on - the button does not appear to be stuck. I can't get the steam to stop... unless I take out...
Yes, if your electric cord was extremely hot to touch is not common. It's posing danger to your unit and to your entire electrical system that may cause fire. Please let a qualified electrician inspect and repair your unit. The unit thermal fuse may not functioning that automatically switch off or cut the electric power of your unit when it gets too hot. Thank you for asking.
Jun 14, 2011 | Tefal Pro Express GV 8120 Iron
Iron comes on but do not get hot
this is due to burning its hot metal card.
Dec 15, 2010 | Black & Decker AS150 Iron
My iron handle where I put my hand gets real hot and there is a smell like plastic burning
You likely have a short in the power circuit or the insulation has failed, or both. It is not safe to continue using.
Sadly, an iron will nearly always cost a great deal more to repair than to replace, but if you are lucky enough to live near an old time small appliance repair shop it is worth investigating.
Farmerbear at FixYa.com
Oct 02, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Handle gets to hot
you just open it and look for whats wrong in your iron.... or the handle in it is not compatable in the iron soo put some leather on the handle...
Jul 24, 2009 | Irons
Burning odor
REPLACE POWER CORD ITS MOST LIKELY WORN BY THE HANDLE WHERE THE RUBBER BOOT IS
Sep 30, 2007 | Kenmore Deluxe KSR400 Iron
Waring WFG150 Panini Press Tostato Perfetto Logo
20 people viewed this question
Top Waring Irons Experts
Are you a Waring Iron Expert? Answer questions, earn points and help others
