Question about Mint Automatic Floor Cleaner
Solid blue light and will not start
Mint 4200 auto floor cleaner has been charging but will not start for cleaning when you push start has a continuous blue light can you help?????
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why is there a red light
Is the red light blinking? Are there any beeps or tones? If so how many beeps?
Jul 07, 2014 | Mint Automatic Floor Cleaner
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
I need an instruction manual for a EUROLAB robot vacuum cleaner Auto Cleaner Intelligent Floor Vac please
I have a Eurolab and I can give you a couple of tips...
Spot = concentric circles from a start point and will continue for 4mins
Clean = will clean until battery runs out then go to base.
Max = will clean until battery runs out and then return to base, charge and go again.
If you interupt any of the settings you will need to manually return unit to charger (either by picking it up- or turning it off on the unit - then turning it on again while holding down "Max" on the unit). It will then find its way home. The two different settings on the seperate little room divider are about how big the doorway distance is ie 1 metre or 4-7 metres (somethinig like that) to prevent it going into a sep room. There is a little filter that needes to be cleaned 1 or twice a fortnight - just to help with suction. The auto settings on the charger unit should be self explainatory but I just set mine off in the morning while I am doing other things and haven't go around to setting it yet. I am very happy with mine and my floor has all of those loose bits gone. I empty the pod weekly.
You can't make it go back with the remote - or if you can it is not mentioned in the manual and I haven't worked it out yet.
I hope this helps.
Cheers
Brittany
Nov 22, 2011 | Vacuums
The suction seems so strong on the floor that it is suddenly hard to push. Don't notice anything thing that would actually lift it off the ground making the suction not so air tight. I have check the...
I'm sorry to hear you're having difficulty using your DC24 on this particular flooring. The cleaner head is designed to adjust automatically to suit the surface being cleaned, and the cleaner's powerful suction causes the soleplate to seal closely with the flooring for high pick-up of dirt and debris. You may find on certain floor types that this makes the cleaner feel a little heavy to push.
Reassuringly, it sounds as if your cleaner is working correctly - however, if you wish to discuss your issue further with one of our experts, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Jul 17, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I HAVE A BISSELL PROHEAT CARPET CLEANER AND WAS WONDERING IF THERE IS AN ATTACHMENT TO CLEAN TILE FLOORS. THANK YOU BONNIE UPDYKE
you should check the website of the manufacturer, be carefull as the grout between the tiles is the weakest link to keeping your floors solid...you may damage or fade the color of u'r grout if it is not protected...and if it is protected and has been sealed with a protectant, then you may be removing the sealant with the extreme hot steam from the carpet cleaner.
Feb 22, 2010 | Bissell 7950 ProHeat Upright Wet/Dry...
Mint Automatic Floor Cleaner Logo
32 people viewed this question
Top Mint Vacuums Experts
JoeVacs
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
