Question about Whirlpool Cabrio Washing Machines
I want to replace lid on my cabrio model wtw7800xw2 with a solid lid frame on glass lid keeps breaking
Same problem. Glass lid failed within 15-18 months. I thought my wife had maybe "abused" the first one. We were very careful after replacing the first for about $180. The second glass lid only lasted another 17 months "being careful" opening and closing. I called Whirlpool customer service just to let them know I was not satisfied and that there is an obvious engineering defect. The manager said that you can read anything on the internet and they do NOT have a problem. I did let them know that I have been an Engineer for 32 years and that this is not an good or even adequate design for plastic construction. I guess she still did not believe me but I requested to have the issue elevated to upper management. It is a shame that Good companies will fail do to the lack of attention to the customer. I replaced the glass lid with a metal one as detailed above. Easy change over and it looks pretty good and a lot better than broken plastic. The washer is a little bit noisier now, but not bad.
Details on removing the plastic/glass lid. Open the lid. Remove (2) screws on each side of the lid at the hinge. Slide lid off. Pull out hinge inward toward tub (they just slide out). Keep plastic bushings. New lid installation. Install one hinge into lid. Just start but not tighten the (2) new screws. Put bushing on hinge outside the lid. Insert into washing machine. (Best to have a helper) Hold lid and insert other hinge into lid. Put other plastic bushing on hinge outside the lid and insert hinge into washing machine. Start the other (2) screws. Align and tighten. Good luck!
Posted on Mar 28, 2015
  • Lora Stokes
    Lora Stokes Apr 23, 2016
    What lid did you use as the replacement? I see that your post say "as detailed above" but I can't find any more info on your replacement of the glass lid with a metal one. Thanks!
  • Tim Haerr
    Tim Haerr Apr 24, 2016
    Sears
    1 pc 8572026 Steel lid $40.90
    2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
    4 pcs W10119828 $3.99 ea (could probably get from the hardware store fo
If all you want to do is to replace the lid, there are two TORX 15 screws on each side. Undo those and the lid should slide right off the pins. Be careful to not drop them into the tub or dispensers. You can then slide the new lid right on. Put the screws back on and test. If you lift the top cover off and mess with the springs, it is a PAIN to take off and put back on.
Posted on Jun 02, 2014
4 Suggested Answers
  • 530 Answers
SOURCE: Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
Posted on May 12, 2010
  • 867 Answers
SOURCE: Whirlpool Cabrio Lid
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
Posted on Mar 11, 2012
  • 3 Answers
SOURCE: glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Posted on Sep 18, 2013
Cabrio wtw7800xl2 Lid frame beaks! Want TO Replace
You can try going to repair clinic at repairclinic.com and probably get the lid along with video help.
Aug 05, 2015 | Whirlpool Washing Machines
How do I change the lid on a Cabrio washer (model # WTW7800XW2)?
If you lift the lid up and go to the base you will see 2 torx head screws on each side remove them lid will slide up an off small tip when trying to remove screws if they are tight or stubborn stop they have a tendency to rust in place you may snap off trying to remove bad design if this happens order new screws 4 and hinges they are different order left and right
Feb 12, 2015 | Whirlpool Washing Machines
Has anyone had the glass top just popped off and is this a common problem?
Yes you would have to open the top cover and tilt it back to be able to get to the lid holder that breaks. Holders are at each end of lid. Labor will cost you if you call a repair company to replace those little weak holders. You may be able to do it your self. Good luck.
Dec 11, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio model # wtw7800xw2 making loud noise durning spin
Most likely cause is the tub bearing is bad.
Link to youtube video to replace bearing..
Whirlpool Cabrio Kenmore Oasis Bearing Repair Part 1 New
Aug 15, 2014 | Washing Machines
Lid problems
If you are using the box to keep downward pressure on the lid because it won't stay closed, you most likely need the left and or right hinge/spring unit replaced, these retail for about $57.00 each. You have two dispenser compartments in the rear left and right, since the bleach is on the left, it often causes rust on/within the hinge assy either from disect splash, or from vapors. If the rear lid trim has come un glued from the lid and the lid is very flimsy, than the entire glass lid needs to be replaced. These retail for about $215.00. Pleazer Appliance...
Apr 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Glass separating from lid
Steel lid retro fit
Solution 2:
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Mar 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
How to fool the whirlpool cabrio 7340 lid switch? how can I look inside the machine while the machine is in operation??????? thanks.
PULL THE WHOLE TOP UP THERE ARE TWO CLIPS THAT HOLD IT TO THE FRAME IN FRONT YOU CAN POP IT UP WITH A FLAT HEAD SCREW DRIVER TO KEEY THE LID FROM CRASHING DOWN ON U TAPE THE LID TO THE FRAME IT SITS ON
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
can be a pain.
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Dropped and broke cover for Rival crockpot model SCV401 need a replacement cover.
Rival Glass Crock-Pot Lid Oval
Fits Rival Crock-Pots using a solid oval glass lid cover
Lid Measures approximately 12-1/4" x 9-5/8" from end to end
Lid is glass with a metal rim
If this sounds like it click on the web link below
http://buyitnow64.stores.yahoo.net/ricrpotslcog2.html
OR IT COULD BE THIS ONE
Rival Crock Pot Slow Cooker Replacement Round Glass Lid Cover
Works with Rival Crock Pot Models:
3300, 3302, 3305, 3351, 3350, 3355, 3504, 3520, 3550, 3500, 3654, 3656, 3760, 3845, 3850, 3950
Approximate total diameter: 10"
Use model number NOT measurements for the correct replacement part
PLEASE NOTE: If your model number has a slash or a hyphen and another number on the end of the numbers above (ex. 3300/2), then this lid will NOT work.
If it sounds like this one click on the weblink below
http://buyitnow64.stores.yahoo.net/ricrpotlidre2.html
Hope this may help.
Jan 03, 2010 | Rival 38601 Smart Pot 6-Quart
Washing Machines Logo
1,153 people viewed this question
Dan Webster
Dan Webster
Sal De
