Question about Foxconn (M61PMP-K) Motherboard
How to flash bios
What flash utility should I use
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Hi, I would like to update my GA-8I848P-G motherboard's BIOS. But I don't know how I can do it. Could you send to a soft to flash the new BIOS?! Kind regards, Grafi
You can get the BIOS flash utility at the Gigabyte website. As far as the actual flashing is concerned, it is a fairly simple and straight forward process. The specifics will depend on the utility that you download. You will need TWO things. The flash utility and the firmware you wish to install. Just a bit of warning, improper flashing of the mobo's BIOS can lead to catastrophic failure of the motherboard, so take care and follow the instructions to the letter.
May 05, 2011 | Gigabyte GA-8I848P-G Motherboard
How to flash my BIOS
Flashing Your BIOS
General Instructions:
Flashing [aka upgrading] your bios should be the last resort to solve a problem. Most people flash to gain the use of larger hard drives although recently, many are flashing to get all the features of XP to work. Other people have to upgrade their bios just to get XP to work properly with some specific hardware.
A couple of items are really important if you decide to flash. First. Make sure the updated bios addresses the issue you are trying to solve. eg many motherboard makers update their bios's for many different reasons. A reason may simply be to get a certain big name brand of pc to work correctly with a new cd writer big brand pc is selling.
So you really have to read the docs so see if the upgrade addresses your specific niggle or concern. Secondly, try your motherboard maker first to see if they have the files you need. Bios's upgrades are best had, if available, from the company that made your motherboard or pc. In most cases these are free.
Thirdly, READ THE DOCS CAREFULLY AND FOLLOW THEM TO THE LETTER. Dont skip any steps, especially the backup option if available. Fourth, if the upgrade calls for a clean bootdisk, use one. The disk I made especially for bios flashing is the one you can download above. It's a DrDOS bootdisk with NO drivers loading up in config.sys or autoexec.bat which is very important. My bios flash bootdisk is recommended by the most popular motherboad makers.
If you dont have a 1.44 drive I also created a utility to use to flash from a CD which you can add the new bios and flash utility to and then burn it.
It should have room to add your new bios, the flash utility, and also have room for the backup. If not one can always use another disk for the info. Always use BRAND NEW MEDIA when dealing with flashes.
In order to locate the correct bios upgrade for your motherboard you need to know who made it AND you need to know the model number. If your PC was made locally perhaps you have the manual. If not, then you need to find out the maker and model. Or, and very common with major brands, your computer maker will/may have the updated bios's on their website.
I have one windows and three dos utils that find your motherboard maker and model number. One of them should work for you. The DOS utils are on my DOStools Page under Diagnostics, and are called CTbios, MBID, and HW iNFO. The windows utility is called BIOS Agent and is on my Utilities Page under Hardware .
Once you ID your motherboard and model go the the manufacturers website and see what they have available. Note that some upgrades will come with their own bootdisk/utility so you may not need the disk I made.
Again, note that even tho many people flash their bios regularly to get the latest features and never have a problem, I still recommend it as a last resort as a flash gone bad will make your pc unusable if the backup doesn't work. Look at it this way, suppose I have a used 80 gig drive I want to resuse and my old P400 cant even detect it so I have an unusable pc. This is the best, and most common reason to flash.
On the other hand, if you have a more modern pc that cant see lets say a 180 gig drive and but all else is working properly then you may want to consider a PCI hard drive controller card which has an onboard bios that will see your new large hard drive and also come with 2 more IDE channels you can use in addition to the 2 channels you already have. This is safer than flashing the bios.
Sep 10, 2009 | Toshiba Satellite M30 Notebook
Flashing the bios
1. Download the BIOS flash utility.
2. Download the BIOS rom file.
3. Format a floppy drive, with system files so that it is bootable.
4. Copy the utility and the rom file to the floppy drive.
5. Boot from the floppy drive.
6. At the c:/ prompt enter the name of the flash utility file followed by the name of the rom file. Example: awd816a.exe romfile.rom
7. Let the program run. Do not turn off your computer until prompted to do so.
Thanks and please take a moment to rate as fixya.
Dec 22, 2008 | Matsonic Computers & Internet
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
BIOS Update Procedure
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.
Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Oct 19, 2008 | Computers & Internet
Foxconn (M61PMP-K) Motherboard Logo
12 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
