Question about Emmaljunga Baby Gear
Emmaljunga easy fix replacement parts
Hi, i have an emmaljunga with an 'Easy Fix' handle for the seat release. The press button has fallen out of one side, can a replacement be bought?
SOURCE: Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Posted on Apr 16, 2008
SOURCE: How do you replce broken door handle?
This is a problem that you should be able to fix. With the interior door panel there are 3 screws. 2 in the arm rest and 1 on the door handle(opener), take those out. There is a C-clip on the window crank that needs to be removed. They make a cheap little tool to remove those but I've heard people using a shop rag and removing the c clip. To remove it, turn crank to around 9 oclock then slide the tool or rag behind the crank also coming from 9 oclock. Any position will work, my point being the tool must slide in from behind the crank handle. Use a flat head screwdriver to gently pry the edges of the door panel away. There are some little clips that pop loose. It's okay if some break you can buy more. After that you will slide the door handle (opener) forward a little to pop out. Twist and turn the panel to get it over the door handle. There are 2 bolts that hold the handle on from the inside. They are 10 mm. You can reach the most forward one pretty easy but the back one is taken out through a hole in the metal door panel. Mine had a sticker over the hole with a big yellow dot on it. After that it takes some pretty good force to get the handle out of the hole. Don't be afraid to push on it. When it pops out take some wire cutters and cut the little plastic clip that holds the metal rod to the handle. The lock twists out of the hole. Now this is when you need 3 hands. Hold the new handle close to the opening and twist the lock into position. Don't attach the metal rod yet. Now actually put your key in the lock. This helps you hold the lock in the correct position while inserting the handle. Put the top of the handle in first and then the bottom should snap in next. Now from the inside, reach up and slide metal rod in the hole and rotate the plastic clip to secure it. Now the hardest thing is getting that back bolt in. It helps again to leave the key in the lock and rotate it so the bolt can secure the locking mechanism to the handle. Put the front bolt in reinstall the interior door panel and you should be in business. Good Luck
Posted on Feb 04, 2009
SOURCE: Rubber on handle of my phil & ted's pram torn - seeking easy fix?
you can buy a replacement handle for £25.00 from http://www.practicalpushchairs.co.uk/accessories/phil-and-teds-other-spares-replacements-parts-spares-nipper hope that helps
Posted on Mar 03, 2009
jp1982
SOURCE: driver side interior door handle
Replace it with the rear doors handle till you can buy one for the rear door. thats what i did.
Posted on Apr 08, 2009
SOURCE: Hi, my bugaboo is now
call bugaboo customer service (1-800-460-2922), give them your stroller's serial number, and they will mail you the replacement kit (the new round buttons) and instructions for free and very quickly - I had the same problem and was very satisfied with how it was resolved.
Posted on May 20, 2009
How to fix trunk lock that just spins
The fix is relatively easy, the hard part is accessing the lock mechanism. You have to be able to open the trunk. Once inside, there is a mount that holds the barrel to the body, and if that has loosened, or fallen, then that will give you your problem.
Jun 05, 2014 | 1995 Pontiac Sunfire
Information about stroller Emmaljunga
I bought a emmaljunga classic pram off a friend but it it 8yrs old. The chassis is broke so i need a new one. I typed the model number into a search online a the chassis now looks different to mine. Mine doesn't have a easy catch on. You have to slide it in to place till it clicks. Any advice to what i should do
Jul 02, 2012 | Baby Gear
I have a Victor R1600 Cutting Torch that the trigger handle malfunctions after a couple weeks of use. The company replaced the first one, but will not replace another, only credit! The problem with the...
Hi:
That's and easy fix and you can do it yourself, call your local welding store like praxair www.praxairdirect.com and give them the brand and model of the torch and they will SHIP direct to you the right part. Check the link here.
Aug 22, 2011 | Victor ST900FC Straight Cutting Torch...
Handle is stuck in the carry position--Can it be fixed?
These car seats seem to have a problem in the release mechanism that
lets the handle move. We have found that lifting the handle a bit as you press
the releases can help. Try pulling toward the front of the car seat, then pressing
the release buttons. If all else fails, call Baby Trend and complain. It just might
get you a replacement if you can prove it is a danger to the child in the seat.
Baby Trend, Inc.,
1607 S. Campus Avenue, Ontario, CA 91761
By Phone: 1-800-328-7363
Mar 26, 2011 | Baby Trend Flex-Loc Infant Car Seat -...
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
The passsenger door opens from the inside but not the outside handle. How do I fix this?
You need to remove the door panel on the inside of the door to gain access to the linkage rods. A linkage rod has fallen off connecting it to the door handle to the door latch. This is an easy fix.
Dec 23, 2010 | 1995 Chevrolet Lumina Apv
I have been given a near new emmaljunga pram- it's navy blue with the white tyes and blue steel all in great working order. The problem we can;t figure out id how to turn the seat attachment to face the...
Where the seat attaches to the frame (on both sides) there is a lever that you undo to release the toddler seat - the lever is on the handle side of the frame. Unlock the lever by pulling it towards the handle, then taking hold of the toddler seat slide it towards the handle. This causes the toddler seat to release and allows you to tilt it and lift out. Turn the seat around and reverse the process, remembering to attach the "lock end" first. Hope this is clear!
Oct 04, 2009 | Emmaljunga Coronado Stroller
Drivers front seat latch doesn't work 2001 beetle
its the cable from the handle to the seat mechanism that locks the seat in place. an easy fix with new cable from vw .i think its a dealer only part !
Nov 29, 2008 | 2001 Volkswagen Beetle
Emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
Aug 02, 2008 | Baby Gear
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
Baby Gear Logo
66 people viewed this question
Top Emmaljunga Baby Gear Experts
Dorel UK
Dorel UK
Are you an Emmaljunga Baby Gear Expert? Answer questions, earn points and help others
