Question about Dometic Refrigerators
Faulty 240 and 12 volt heaters
Rm4211
    Top Expert:
  • Dometic Master
  • 8,175 Answers
Replace element
Posted on Jun 21, 2016
How to check the heating elements in GE harmony dryer
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Oct 29, 2014 | Dryers
Why does Heater keep shutting off and on. Tech says everything looks ok by milli volt readings
problem is you either have a poor neutral connection, one of the safeties is opening and closing at times, or the gas valve is faulty
Jun 30, 2014 | Raypak 2100 Pool Heater Gas 266000 BTU'...
I have a LX250N heater. When I attempted to start the heater this year to no avail. When I turn the heater on and raise the thermostat to demand heat I hear once click but the blower never comes on. Can...
safety circuit will not let blower turn on check to see if 24 volts ac on both sides of pressure switch if ok see if 24 volts at gas valve brown and yellow wires if not safety circuit open check copper tube to pressure switch to see if clogged
Jun 26, 2014 | Jandy LX 250N Lo-NOx, 250,000 BTU Heater,...
Recently installed leviton combination switch was working correctly. Now when power is being drawn by the hot water tank it controls the pilot light goes out. Any suggestions or is the switch faulty?...
Pilot light switch is usually rated 15 amp.
Check amp rating of device.
Check volt and watt rating on nameplate of water heater.
4500watt element divided by 240volts = 18.75amps
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
If you have 120Volt under-counter water heater, then add a comment.
I recommend using contactor to control water heater when using a switch rated for less than 30amp.
Contactor controls water heater. Switch controls contactor.
http://waterheatertimer.org/Ordinary.html
http://waterheatertimer.org/H230A.html
Aug 24, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
The water heater red light keeps flashing rapidly on my Powervent 2 model 41VRP40N. It is not producing hot water and when I read the manual it says it needs more heat. What does this mean. How do I fix...
There are many things to check. The single most important test is for 24V at the gas valve after the ignitor is supposed tp be on. 19 V or less and there is either a bad ground or the ingition control board has failed. (Wire ground problems are a high probablilty)
Here is what the book says:
PROBLEM #1 - HOT SURFACE IGNITOR DOES NOT GLOW RED
(Remember to wait for purge time, 17/34 seconds, on models so equipped).
Possible causes
A. No main power
B. Faulty transformer
C. Faulty thermostat
D. Faulty limit switch
E. Faulty blower interlock switch
F. Faulty hot surface ignitor
G. Faulty ignition control
Solution
Step #1
Perform normal system checks of main power, transformer, thermostat, limit
switch, blower interlock switch, and replace faulty component.
Step #2
With power on and thermostat set at its highest position, check voltage
between "TH" and "TR" on HS780 ignition control. If 24 volts is not present
check output at transformer. If no, replace transformer. If transformer
checks out OK look at other controls in the 24 volt circuit I.E.: thermostat,
limit switch, blower interlock switch. Check for 120 volts between "neut"
(L2) and "120" (L1). Check for 120 volts at the ignitor across "IGN" and
"IGN" terminals on the HS780 ignition module. If 120 volts is present,
replace ignitor. If no, replace the 780 series module
PROBLEM #2 - IGNITOR GLOWS RED BUT MAIN BURNER
WOULDN'T LIGHT
Possible causes
A. Improper ignitor alignment
B. Faulty ignition control
C. Faulty gas valve
D. High inlet gas pressure
E. Polarity reversed
F. No earth ground
Solution
Step #1
Check for availability of gas at gas valve. Make sure the manual valve
upstream of the gas valve and the gas valve are in the full on position. Also
make sure gas is being supplied to the system at the proper pressure, too
high will lock-up the valve.
Step #2
Check proper polarity of "NEUT" and "120" on the ignition control by reversing
the wires, if reversed gas valve will not open. If this does not solve the
problem, replace wires as they were.
Step #3
Check for proper ignitor position.
Step #4
Check for a good earth ground by using a meter connected between L1
and furnace chassis. Should read 120 volts, if no, check and/or repair ignition
ground wire or ignition control mounting screws.
CAUTION POLARITY MUST BE OBSERVED
Step #5
Check for 24 volts at the gas valve terminals; "1" and "2" on a 7200 series,
"M" and "C" on a 7100 series, "TH" and "TR" on a 7000 series. If yes,
check wire integrity or change the gas valve. If no, change the 780 series
ignition module.
That is pretty much all of the troubleshooting required.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater does not work
The heater not working.This problem is related to few possibilities 1) The thermostat can be faulty. 2) the heater blower motor resistor is faulty 3) The heater blower motor it self is faulty. ------------ The The blower resistor is behind glove-box on plenum.Connect the 12 volt battery directly to the heater blower motor and see,if the motor runs then its faulty resistor or thermostat.but if no motor running then its faulty motor. The thermostat is located at the top front of the engine.For easy access follow the top radiator hose.The top radiator hose goes in engine .Take that hose out and thermostat will be seen inside. --------- The thermostat and resistor are not very costly part.So you can directly replace them and see if its helping.First confirm motor is working,by directly by passing the blower motor to 12 volt battery. ------------ This will help.Thanks.Helpmech.
Dec 17, 2010 | 1998 Honda Passport
Heater blower hooked up not working new resister and all good fuses
The heater blower motor needs to be checked.If the resistor is replaced but still the motor is not getting started then its faulty heater blower motor.Get the 12 volt checked by meter to confirm power to the motor.If no power then its faulty motor causing this problem.
Nov 08, 2010 | Ford F-150 Cars & Trucks
We have a Bosch WTL 6301 , as the heater not working so what I can do , I have test the Heater and its Ok but no electric comes to it
Could be a faulty thermostat/s, or the timer control unit could be faulty.
The power goes to the thermostat/s before going to the heater.
Mar 09, 2010 | Bosch Axxis WTL 6106 Electric Dryer
It works on 240volts and gas but not on 12 volts. Why and how do I gain access to the parts that I must test?
in the rear it have a round element you will see there are four wires going in the 12v side must be tested if there are any circuit if not it need to be replaced
May 18, 2009 | Refrigerators
Indesit
If the water does not get hot, I assume the machine does not complete its programme? Since you have changed the stat, AND checked the element I think the timer may be faulty.
OR has a wire burned off in the heater circuit somewhere? You can test for a 240 volt supply at the two ends of the heat element with a meter, or even a 240 volt bulb.
!!BE CAREFUL!!  !!OF 240 VOLTS !!
Oct 31, 2007 | Indesit W 123 Front Load Washer
Refrigerators Logo
27 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
