Question about Peavey Electronics Peavey Max 112 Bass Guitar Combo Amplifier
Peavey 112 max bass amp combo no power
I ahve a peavey bass amp 112 max combo amp that Will not turn on it dosent seem to be getting power .. Any ideas where i should start also a wiring diagram could be helpful ... thanks
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a Peavey MAX
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Posted on Apr 23, 2011
Peavey 115s bass amplifier
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Apr 04, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
How do I go about disassembling my peavey 6150+112 combo guitar amp to the point where I can replace the 12" driiver for a better one.
Most Peavey speakers you will have to just remove the grille in front of the speaker. These usually are held by Velcro like fasteners that you must carefully pry the grille out. That will give you access too the screws holding the speaker rim. Be aware that there are different sizes of speaker rims and mountings for the "same" listed size speaker. Also use the same impedance speaker as the original one or you MAY find you have less power OR blow your amp out.
Jul 30, 2011 | Peavey 6505+ 112 Combo Amp Combo
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
Peavey Electronics Peavey Max 112 Bass Guitar Combo Amplifier Logo
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
