Question about Electrical Supplies
Not getting spark to start troy bilt 55500 generator
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 4088 Answers
SOURCE: troy bilt gas portable generator not producing
First thing to check is to see if the generator is actually turning--couplers sometimes fail. You need some electrical skills and a voltmeter to trace down problems in the generator beyond checking the health of the two brushes that supply current (< 115 volts DC) into the rotor field circuit. You can find wiring and schematic drawings on the Troy-Built web site, just look for the 030248 model. Another person that I worked with had a similar unit with the same problem. It looked like the voltage regulator board was the problem, but haven't heard back if he had fixed it.
Posted on Sep 26, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Posted on Sep 30, 2009
  • 151 Answers
SOURCE: Troy-Bilt 5550 generator. After starting if I move
improper setting in the fuel needles of the carb. what size is the engine? brand?
Posted on Dec 24, 2009
witserv
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
Jun 07, 2017 | Electrical Supplies
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
What engine oil is used for a model 01919, 5550 watt Troy-bilt genertor?
The generator engine is shipped from the factory filled with
oil (API SJ or higher 10W-30). This allows for generator
operation in the widest range of temperature and climate
conditions. Before starting the engine, check oil level and
ensure that engine is serviced as described in Maintenance.
This is from toy bilt manual >Good Luck...
Aug 31, 2011 | Troy-Bilt Garden
I need a manuel or starting instructions for a 8000 Watt Troy Bilt generator.( Model number 65157/30247. This is an electirc or manuel start.
See this webpage for manual:
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/030247-0/Troy-Bilt%20Portable%20Generator%20Operators%20Manual/030247_0esCw/
Feb 19, 2011 | Garden
Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
May 06, 2010 | Troy-Bilt Pony Garden Tiller
Jun 20, 2009 | Electrical Supplies
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-BiltĀ® Briggs and Stratton Chipper
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
