Question about Maestro Electrical Supplies
Blinking lights Sylvania light disk
Tv turned off. Will turn on to standby light. Green powerr light flashes and then tv turns off back to red standby light. No picture. What to do?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 26, 2015 | Sylvania LC420SS8 LCD TV
Green light flashes back red
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sylvania LC420SS8 LCD TV
Wi-max light deep blue Power and charging and battery light blue-white HDD light blinking
Make sure your dvd rom does not contain a disk.
Your system checks your dvd rom drive first for a bootable disk.
A blinking HDD light is normal during boot up.
Feb 06, 2013 | Toshiba Satellite Computers & Internet
Why is my hard disk drive indicator light always blinking on my Sony Vaio Laptop? My laptop reads cds and dvds fine, it is just annoying to always see it blinking.
This is perfectly normal. Your hard-disk indicator light is always blinking because your hard-disk is constantly being used by the operating system. Windows and other applications are performing operations in the background which require both reading from and writing to the hard-disk regardless of whether you are doing anything or not.
You only need to worry when the hard-disk light STOPS blinking . . . permanently!
Nov 03, 2010 | Computers & Internet
, hard disk problem
Hi, blinking light may indicate activity to or from hard disk and computer, maybe the disk partition was damaged or lost due to incorrect ejection or a virus, you could use a free partition recovery software to try to fix it, for example EaseUs.
Dec 23, 2017 | LaCie Big Disk External USB 2.0 1TB Hard...
Monitor isn't working after move, power light blinking, blank screen, user controls doing nothing, need manual to see what's wrong, but Sylvania on-line information is amazingly bad.
Connect the monitor to a laptop computer, to see if the laptop can "paint" anything onto the screen. If not, then the monitor was "killed" by the move. Is the monitor still under warranty?
Oct 29, 2009 | Sylvania Computers & Internet
I have a sylvania model LD370SC8S 37' i turn it on it comes on but goes to a blinking green light
i had the same problem, i just separated the wires & taped the parts where the wires came off
Jun 16, 2009 | Sylvania LC320SS8 32 in. LCD Television
Hi i have a 42'' 42'' sylvania pla model 6842 pf m and have a bli
if stand-by voltages are good, you probably have bad inverter board. could be one or two depending on unit
Mar 09, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
TV will not turn on
I suspect you may have a short in your horizontal deflection circuit that is keeping your power supply from fully energizing. I do not have any information on this model and suspect that it is actually made by symphonic/Funai corp which puts it in the disposable Tv catageory in my opinion.
Apr 10, 2008 | Sylvania 6427FF TV
Electrical Supplies Logo
53 people viewed this question
Top Maestro Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Steve
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
