Question about Apple MacBook Pro Notebook
My intenso external hard drive (640gb 2.5") is not readable by my macbook (usually it works fine).. I also tried to check whether i can repair any issues from Disk utility but the option is not available in First aid
    Master:
  • Apple Master
  • 545 Answers
If it works fine elsewhere, then Im stumped. From your description, the drive doesn't sound like it's operating correctly.
Posted on Jul 18, 2014
  • 53 Answers
SOURCE: macbook Leopard 10.5.6 cannot open any
could be a hardware problem to be honest. heres what you should try: load a system disk and hit C during boot up and see if you have the same symptoms in disk boot mode. if you do, than it is most likely a hardware issue. if you dont, it could be software related. if that doesnt work: hit V when you boot up and it will go into verbose mode. this will show you all of the background processes that are working during startup. while watching the screen, check to see if you have any stalls during load and note them. also, disconnect all peripheral devices and try removing ram (1 stick at a time) to see if that is a problem as well.
Posted on Jun 08, 2009
SOURCE: Intel Macbook Flashing Folder, wont boot DVD
Just a note--any Universal retail OSX install disc will work. It's only a machine specific disc that won't unless it's for your model.
Posted on Jul 08, 2009
Macs R We
  • 481 Answers
SOURCE: trying to fix a grey screen problem on a macbook.
Since no MacBook was ever made with an 8GB hard drive, I have to assume you are reading the capacity of the DVD, which isn't an interesting statistic.
There is no reason your MacBook should not boot from the DVD. Even if the internal drive was physically absent it should still boot from the DVD.
If it is not booting from the DVD, then either your DVD is bad, your optical drive is bad, or you have logic board issues.
Posted on Oct 28, 2009
  • 846 Answers
SOURCE: Power up and get the sound and then a white screen
This looks more like an issue w/ your motherboard, since it should at least give you a file folder with a question mark if it was a hard drive problem only. Try to boot from the install CD, if that succeeds, all you probably have is a broken filesystem (reinstall) or a broken hard drive (replace). There are Mac Repair Guides that show how to open a Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Posted on Dec 27, 2009
APPLESUPPORT
  • 70 Answers
SOURCE: Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Posted on Apr 20, 2010
When i plug my 64GB intenso memery stick into my laptop it does not read,the capacity of the stick is not shown and i cannot open the and retrive the files that are in it
It appears your drive has failed. I would recommend checking the USB drive is not damaged in any way, perhaps the USB plug on it needs re-soldering, I have had memory sticks in the past with the same issues which were cured by re-touching the solder bonds for the USB plug.
Mar 18, 2014 | Intenso 6002510 Memory Station 320Gb Usb...
How do I use an Intenso external hard drive?
You shouldn't need any driver or software to use this hard drive. It should just plug in and mount as another drive. You can use a file manager to move files and directories, just like it was any other drive. If that works, uninstall the ArCSoft app, it's just useless.
Apr 06, 2017 | Computers & Internet
I bought an Imation Apollo II (320GB) and had it formatted for my macbook in the store I bought it. It has worked fine up until 2 days ago. Now, when plugged in, it says only 'the disk you inserted was...
Hello barry_carrot,
I work for Imation and we would advise you to try the following option:
restart to your Macbook without the external drive attached.
Open your Disk Utility (in your Applications/Utilites folder).
Plug in your hard drive.
If the drive shows up in the list in the Disk Utility First Aid window, click on the drive, and then click on Repair Disk. If the process repairs anything, run the same Repair Disk a second time to see that it runs with no problems found. If some other error comes up, or it won't repair a problem found, then I would recommend moving this drive to a PC, and trying a repair tool through Windows.
Note: if you see the "repair" option grayed out, Going back to Disk Utility - (you won't be able to select Verify/Repair Disk Permissions), but Verify or Repair Disk should be available if you click on the device (the entry showing the manufacturer's info for your external drive).
If that doesn't help you, please contact the Imation product support department at the phone number 1-800-351-8186 option 2.
Jul 20, 2011 | Computers & Internet
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
Disk is not readable by the computer.
Try a different "data" cable between your computer and the external disk-drive.
Try connecting the unit to a different computer.
If it fails there, then the unit itself has a problem:
Either:
* the USB-to-disk-drive adapter (inside the casing) has failed;
* the disk-drive (inside the casing) has failed.
Disassemble the external unit, and remove the disk-drive. Connect it as a "slave" disk-drive in some Apple Computer, to see if the data on the disk-drive can still be accessed.
Check with LACIE, to see if their "warranty" is still valid, or if it has expired.
Apr 08, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
We have a Comstar 640gb external Hard Drive. All tests say drive is healthy. Running Windows XP. Drive was working yesterday when hooked up to our old PC. Now on new PC Windows will see the HD and we can...
Can I ask a question about this Comstar 640gb external Hard Drive? What kind of power adapter for this external Hard
Drive? How many volts? I lost my power adapter for this hard drive while moving.
Steven
Feb 04, 2010 | Fantom Drives Titanium II (TFD160U2) 160...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
WD 500GB external hard drive won't load on new macbook
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :honglake@gmail.com
Mar 19, 2009 | Western Digital 500GB My Book Pro-External...
Apple MacBook Pro Notebook Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
