Question about Master Lock Locks & Locksmithing
How to fix a master lock that won't lock shut
My master lock lock will not lock shut
My sliding door won't lock with the key, fob or the internal button so have to lock manually from inside on my renualt master. Any simple ways of fixing it
Clean the contact on the sliding door that mate to the body pillar and see if that is the problem, if not the lock motor may be at fault. Have a qualified technician verify the concern before buying any parts please. I am just guessing here.
Aug 25, 2012 | Renault Cars & Trucks
Encryption accessibility
I met the same trouble, i just reset acer password by the following steps,
Step1.Download Smartkey Windows Password Recovery from recoverlostpassword.com anddecompress it on that PC. There is a .ISO file. Burn the .ISO file to CD or USBFlash Driver.Step2.Get out the newly created CDor USB Flash Driver and insert it to the locked computer.Step3. Re-boot the locked computerand then follow the process of instructions. Just after a few steps, the oldpassword will be removed.It can recover all Windows version.
May 14, 2012 | Acer Aspire One A150-1049 Notebook
Shure slx1 won't shut off
You have probably locked the controls.
http://shure.custhelp.com/app/answers/detail/a_id/3192
Jan 26, 2012 | Shure SLX1 Body-Pack Transmitter for...
How to fix brakes that will not release?
need more info ..like yr and make /model of vehicle
Jan 02, 2012 | Cars & Trucks
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
The indicator lights on my dash for the anti-lock, the brakes,and low tire won't shut off eventhough i just fixed all three.
IF YOU SEE ANTI LOCK AND BRAKE WARNING LIGHTS YOU HAVE BRAKE FAILURE.NOT SAFE TO DRIVE CAR.BEST TO LET DEALERSHIP FIX ABS BRAKES MODULATOR MASTERCYLINDER UNIT AND THEY CAN RESET LOW TIRE LIGHT.VECHICLE NOT SAFE TO DRIVE.
Jul 28, 2011 | 1999 Oldsmobile Alero
Brakes won't release with out braking bleeders loose all new pads when bought 2-weeks ago guess i am the fool
Please do not despair, you have your work cut out for you but it is a relatively easy fix. Your brake master cylinders are dirty and plugged with rust. You will have to take apart and clean your brake master cylinders. Consider purchasing the rebuild kits and replacing all the rubber parts in the master cylinders and the caliper pistons. This will ensure you many trouble free years of operation in the future. If finds are tight a simple cleaning of the master cylinder reusing the old parts should suffice. When you rebuild your master cylinder you will need to look down the reservoir at the large brake fluid feeder hole. Right next to it is a tiny pin hole. That is the brake fluid return hole for the reservoir. It is probably plugged with rust or dirt. When it is plugged , you drive a short distance and the wheel locks up. Open the bleeder screw to release a squirt of fluid and you can drive back home before it locks up again. Clean out the hole with a single straight bristle from a wire brush and see if that fixes the problem. You may not need to disassemble any thing to get the systems working properly but you will need to do a thorough bleeding to get all the **** out of the brake lines. This is a common problem on all older machines when the brake fluid is allowed to sit in the system for many years unchanged. Use only new quality DOT 3/4 brake fluid when refilling the reservoir.
May 30, 2011 | 1983 Honda GL 1100 Gold Wing
I have sagem my101X mobile but when ever i on it it shows sim locked and asks to enter unlock code what should i do?
If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
nothing plays
1.no disc 2.finalised.3.right region code and matching dvd, infront of your manual says discs won`t play.
mobile passcodes
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope that helps
Nov 20, 2009 | Nokia 6233 Cellular Phone
Master code setting couldn't do it (alarm system ADEMCO VISTA-10)
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jun 14, 2009 | Eagle SeaChamp 1000c Recording Sonar...
Locks & Locksmithing Logo
21 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Lawrence Oravetz
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
