Question about Kenmore 55603 Side by Side Refrigerator
Door Handle Issue
Top of the door handle on the refrigerator side popped out of place (not detached though.) How do I reattach so that it is flush?
You need to get a small allen wrench and put it in the side of the handle and twist it. It should take about 30 sec to fix your problem. Maybe a little more depending on how long it takes you to find the right sized one. Depends on your model but that is how mine worked.
Posted on Jan 07, 2008
  • 473 Answers
I may need the entire model # off the sticker inside the fridge section to help.  Most side by sides have a slot that the handle fits into and just pull down hard to lock into place.  May need to take the handle all the way off and tighten the screws on the handle and on the door first.
Posted on Oct 27, 2007
My back driver side door wont open. why is that
The door latch is locked in place or the door handle assembly connected to it has detached. Try taking the interior panel off and reattach or jimmy latch until you open and WD40 it or replace if really bad
Sep 02, 2010 | 1996 Dodge Intrepid
Trying to remove rear door handle on chrysler lhs 99
Hello, to remove and replace the rear door try the following:
1. Disconnect the negative battery cable from the battery of your Chrysler LHS. You can accomplish this with an open end wrench, to prevent any injury or short in the electrical system as you are working on the door lock switch. Place the negative battery cable out of the way so it does not touch any metal parts.
2. Undo any screws that are holding the lower door panel to the door with a screwdriver. Unclip the plastic hold clips that are attached to the back of the panel by carefully pulling them away by hand.
3. Locate the electrical connector wires. These wires run behind the panel to the door arm rest and detach each wire connector by hand. Remember how the wires were attached so you can put them back the same way when it is time to reattach them.
4. Lower the door panel away from the door. Then, remove any screws holding the upper door panel in place. Remove the door handle pull cup that covers the door lock switch and door handle by carefully popping the cover off after you have removed the screws holding it in place.
5. Detach the upper door panel from the door. You can do this by pulling it away carefully from the plastic clips. Move the upper door panel out of the way and locate the door lock actuator switch. Remove the screws from the actuator switch that are holding it in place and disconnect the electrical wires attached to the back of the switch.
6. Replace the old door lock actuator switch with a new one. This replacement can occur by connecting the electrical wires to the back of the new switch and reattaching the switch to the door frame with screws. Put the upper door panel back in place, securing it to the door frame with plastic clips and screws.
7. Reattach the door handle pull cup to the upper door panel with screws. Then, put the lower door panel in place and reattach the electrical wires to the window switches underneath the armrest. Attach the lower door panel to the door frame with plastic clips and screws.
8. Attach the negative battery cable to the Chrysler LHS battery with the open end wrench.
Jul 27, 2010 | 1999 Chrysler LHS
How do i tighten miele refrigerator door handle
grip slide on side of door handle and pull door handle to open position slide will detach from handle exposing 4 torx screws tighten screws and refit slide
Apr 29, 2010 | Miele KFN8462S Bottom Freezer Refrigerator
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
The door handle on my sub zero 650 has come off.
On Few Models, To remove the existing handle have a look for clipped on covers hiding the screws.On others, With a small flat blade screw driver stick between the handle and the door trim on top and push it up and on the bottom push it down and you can access the screws in the handles and tighten.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 05, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore 106.55526400 door handle needs mounting
Yes the door will need to be partially disassembled to reach the back of the screws. The handle is the lowest price I could find is at Sears Parts Direct CLICK HERE=>
Get an account and enter model number.
To see the photo of the door click here below
If you need more help please let me know.
Trying to help but, Not sure you will be interested in the repair, Thanks, Sea Breeze
Aug 15, 2009 | Whirlpool ED2FHEXN Side by Side...
Handle has pulled away from the door. How can I access the screws
Realized the top chrome part split into 2 pieces and then was able to remove the wood like strip in the chrome strip. Popped the top chrome anchor, reattached the handle bracket as the screw holes were not stripped, put the wood like strip back in place and slid the top chrome anchor back in place.
Feb 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Switching doors to open the opposite direction
Look on the other side of the door and see if there's a plug covering a hole even with where the door handle attaches on the opposite side. If so, I think you just unscrew the handle from the top of the fridge door or bottom of the freezer door an unhook the other end and reattach on the other side of the door. And unscrew and move the hinge to the opposite side. If your doors can be reversed the holes should arleady be in place. It didn't look overly difficult when the delivery guy changed mine when the fridge was delivered.
Nov 24, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 55603 Side by Side Refrigerator Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
