Question about DeLonghi Irons
The steam button doesn't work,does steam like it should
When I push the steam surge button it gets stuck so it doesn't steam much anymore
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Posted on Apr 18, 2007
ercupa190
  • 12223 Answers
SOURCE: The steam button is stuck on (pushed in) but there's no steam.
follow this steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Posted on Nov 15, 2012
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Leaky steam iron
First of all make sure it is air tight! If it has a crack or a break in the seal its probably not going to do you any good anymore. Try washing it and rinsing with vinegar to remove any material that may be stuck in there or get rid of mineral buildup from steam and water over time.
Apr 23, 2015 | Rowenta Power Duo Iron
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Nov 15, 2012 | Black & Decker Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
It will not steam or surge anymore.
Lay a very thick towel on your itoning board.
Fill your iron with white vinegar lay it down and let it steam itself dry.
Jan 17, 2010 | Black & Decker D2030 Iron
Steam Station FCL-SS167 Purchased today followed instructions for first time use when plugged in green indicator light does not light up and it does not steam unless surge button is pressed then it makes a...
NO IT NORMAL , THE WTAER HAS TO REACH 100,dec IE , BOILING POINT BEFORE IT CAN STEAM , NEXT TIME WAIT A BIT LONGER AND YOU SHOULD GET THE GREEN LIGHT .
Nov 05, 2009 | Irons
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Steam button wont push down
Sep 10, 2006 | Rowenta Professional DE880 Iron
Irons Logo
Top DeLonghi Irons Experts
Are you a DeLonghi Iron Expert? Answer questions, earn points and help others
