Question about Bosch PB10-CD Radio/CD Boombox
No blue light and radio
Have no power for radio and blue light
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
What is the wiring diagram for the stock radio
Check this...
1998 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5" x 7" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rate and comment this answer).
Feb 16, 2011 | 1998 Ford Taurus
Need the wiring diagram for the 2009 Toyota Corolla
standard radio--------------------
Battery LIGHT BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna TAN (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Dec 12, 2010 | Car Audio & Video
I need a wire diagram for 96 a chevy lumina and a 95 cutless supreme oldsmobile for stock steroes
96 Chevy
Battery ORANGE (+) RADIO HARNESS Accesory YELLOW (+) RADIO HARNESS Ground BLACK/WHITE (-) RADIO HARNESS Illumination GRAY/BLACK (+) RADIO HARNESS Dimmer BROWN/WHITE (+) RADIO HARNESS Power Antenna PINK (+) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE
Apr 04, 2010 | Car Audio & Video
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Illumination Wire: Blue/Red
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Oct 01, 2009 | 1995 Jeep Cherokee
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
95 olds aurora radio wiring
Power Antenna DARK GREEN (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
Amp Location TRUNK,ON BACK SEAT
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Apr 12, 2009 | Sony Car Audio & Video
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Ground Wire: Black/Green
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Aug 14, 2008 | 1988 Ford Mustang
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Bosch PB10-CD Radio/CD Boombox Logo
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
