Lettera 25 repair no sirve tevclados
Broken Platen Knob on Olivetti Lettera 25
Platen knobs are usually held by an Allen screw in the side of the shaft, which can be hard to see and get at, but have a good look.
Jan 20, 2010 | Olivetti Lettera 25 Typewriter
Did anyone answer the problem of unlocking the carriage on the olivetti lettera 22? thankyou
There is a small lever on the right side of the machine under the carriage that is meant to lock the carriage for transport. Press this down.
Nov 08, 2009 | Olivetti Lettera 25 Typewriter
No ribbon lift
Make sure your cap lock key isn't pushed down. This will disable ribbon shift.
Sep 18, 2009 | Olivetti Lettera 25 Typewriter
Is there somewhere in Australia where I can buy ribbons for the Olivette lettera 32
These ribbons are getting harder to find because the spools are no longer made. I suggest that you buy a ribbon the same width 1/2" and wrap it on your spools.
DickyO
Sep 11, 2009 | Olivetti Lettera 25 Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
Olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
Mar 19, 2009 | Olivetti Lettera 25 Typewriter
Cant move carriage lock lever on the olivetti lettera typewriter.
it should slide from front to rear.Maybe it could use a drop of oil.I use Marvel mystery oil
Jan 01, 2009 | Olivetti Lettera 25 Typewriter
Ribbon supply
This ribbon fits many different typewriters 25 and 35 are the same. Spool should be the metal type not the plastic, and you need the nuts on the top....
Mar 20, 2008 | Olivetti Lettera 35 L Typewriter
23 people viewed this question
k24674
jasbo
jasbo
