Question about Karcher K DS 5500 Vacuum
Manual guide for karcher DS 5500 - Karcher K DS 5500 Vacuum
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
The on/off switch doesn't work, vacuum cleaner stays on until unplugged.
It might be a simple switch issue. I would take it to a vacuum repair shop, one with free estimates. This way you will know for sure. and it should not cost you much?
Nov 12, 2009 | Karcher K DS 5500 Vacuum
No suction at all! help
check your vacuum at the pickup all the way thru the hose to the bag, you might be stopped up somewhere.
Jul 09, 2009 | Karcher K DS 5500 Vacuum
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
Oct 09, 2008 | Karcher K DS 5500 Vacuum
5500 model
change the filters & ensure that the water container is properly seated in the machine.If the water tank is not sealing correctly the machine will not genrate any suction.
Aug 08, 2008 | Karcher K DS 5500 Vacuum
K5500 vs DS5500
The K5500 is an older model and doesn't come with the same amount of tools that the DS5500 comes with. You can usually tell the difference that the K5500 is an older model as its grey with yellow inserts. The latest DS5500 is all in yellow with black inserts and has some improvements made to the durability of its plastic body.
Mar 29, 2008 | Karcher K DS 5500 Vacuum
Karcher K DS 5500 Vacuum Logo
Top Karcher Vacuums Experts
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
