Question about Vacuums
Eureka Smart Vac Bagged Pet Lover model: the roller stops when vacuuming carpet. I have installed a new belt. I have the vac on the highest carpet setting and it still stops the roller brush upon contact with the carpet. My carpet is also short napped. I installed a new belt when this problem developed and the new belt has made no difference. The roller will spin if I angle the machine up and off the carpet completely. What is wrong?
    Top Expert:
  • Vacuums Master
  • 41,738 Answers
The brush roller end caps may be clogged with pet hair and other debris.
Posted on Jun 13, 2017
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Eureka Smart Vac Brush not rotating when touching floor
Sounds like either the belt wasn't routed correctly or the idler clamp asm.(part # 704194CSV) has a problem. There should be a diagram showing the belt placement either by the belt or on the inside of the cover.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
SOURCE: Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Posted on Dec 29, 2008
ftw1952
  • 10319 Answers
SOURCE: Eureka Boss smart vac. Brush
generally when this happens either the belt is stretched or the brush bar is simply worn out and down were the area the belt rotates on
Posted on Dec 29, 2010
  • 147 Answers
SOURCE: Hey everyone, first time on forums. I have a
Change the belt on the unit, and adjust the height adjustment until the brushes are just touching the carpet. I know you mentioned the belt looks good, but when you get the new EXT-U belt, you will notice a size difference. Good luck!
Posted on Jan 25, 2012
Eureka burning smell
Hi, it's Cindy from Crucial Vacuum.
Since you have replaced your Eureka 4870MZ 9200 Proheat 2x vacuum's belt, the issue may either be caused by your roller or the position of your belt. It sounds like as soon as your vacuum is lowered, the belt is either slipping or wear on the end caps is causing your roller to stop. This will cause the burning smell since your motor is now straining against the abrupt stop. Try taking off your roller and checking the conditions of the end cap or try to reinstall your belt. I have included an instructional video: http://youtu.be/rji0fl9hytY
You can purchase direct your replacement brushroll from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-smart-vac-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 20, 2013 | Eureka The Boss SmartVac Upright Vacuum...
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
On our eureka world vac 9834 we cannot figure out how to remove the roller so we can put a new belt on
On this particular model the TOP cover is removed. There are 2 phillip screws near the roller and 2 tabs near the back wheels (push in with a flat screwdriver while pulling apart). Pull the hose through cover for easy cleaning. Everything I watched or read were for other models, where the bottom cover was removed :-(
Feb 10, 2011 | Eureka Boss 7601 Bagged Upright Vacuum
The roller is not turning after i caught up a frayed carpet string.
This could be because of 2 things on this model.
1) the model MAY have a white reset button on the side of the unit that the hose does not go into. Sometimes to prevent a toothed belt from damaging the motor.
2) the belt may need to be changed on the unit usually noticed with a burning rubber smell when you caught something. this just requires a belt change.
Nov 03, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
How to replace belt on a eureka boss vacuum
if you look on the base plate you should see a diagram of how to do it,but if yours don't have a diagram then remove the screws from the base plate it should be three or four they have arrows next to them. take the base plate off and remove the brush roller and the old belt off being sure to put on bear floor then put the belt on the drive shaft put the brushroller in left side first
Jun 28, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a eureka the boss smart vac petlover vacuum and I cannot find the book on how to replace the belt. I have opened it up, but there is a silver roller that is confusing me.
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
Oct 10, 2009 | Vacuums
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Oct 24, 2008 | Eureka Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
