The Whirlpool washer stops at Rinse in all modes
The Whirlpool washer (Mod.LSQ9520LT0) goes through the washing cycle, drains all the water and stops at the "rinse". If I turn the knob slightly it continues and finishes the cycle. I tried Permanent Press and result is the same. I checked the lid switch for continuity. It seems to be working just fine. What could cause the problem?
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Change the cold water valve
Posted on Feb 11, 2014
  • 1122 Answers
SOURCE: Whirlpool Thin Twin YLTE6234DQ2
YOU CAN DO THIS.,POP THE FRONT PANEL OFF,GO TO THE SWITCH PLUG JACK ON RIGHT SIDE UNPLUG JACK,ON THE SWITCH SIDE WIRES CUT THE OUTSIDE WIRES PUT THEM TOGETHER WITH WIRE NUT,LEAVE GREEN WIRE ANONE,PLUG BACK INTO JACK,YOUR DONE,REMEMBER NOW IN THE SPIN CYCLE IT WILL WORK BUT WHEN YOU OPEN THE LIP IT WILL NOT TURN OFF SO KEEP YOUR HANDS OUT OF THERE,THANKS-MIKE
Posted on May 28, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    • 18 Answers
    SOURCE: Maytag Washer Getting stuckon wash cycle
    the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
    please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
    these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
    Posted on Dec 27, 2008
    michiganfan9
    • 179 Answers
    SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
    your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
    Posted on Dec 30, 2008
    • 188 Answers
    SOURCE: Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Posted on Mar 03, 2009
    Whirlpool washer model lsr8233eqo
    So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
    Feb 03, 2013 | Whirlpool Washing Machines
    Washing machine stopped on the rinse cycle and will not start again it has power to it so it is not the cord.
    My whirlpool front loader washer is stuck on drain cycle then shuts down for a while . if you turn the knob to a different cycle number it still goes into drain mode
    Jul 25, 2010 | Washing Machines
    Washing machine wont hold water on any setting
    raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
    Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
    Won't drain water for rinse
    your lid switch is defective..replace onthejob
    Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
  • Nov 20, 2008 | Washing Machines
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer will not drain after wash cycle or the spin cycle
    check to see if your pump is slightly plugged with a sock or ?
    Your top loader should pump out in about a minute and a half when totally full of water.
    Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
    Washing Machines Logo
    78 people viewed this question
    Top Washing Machines Experts
