Question about Tunturi T85 Treadmill
Motor Tunturi T85 overloaded
Start running programm --> normal for a few seconds --> motor stopps (message overloaded). pressed several times on/off switch --> doesn' t work no more (message motor overloaded disapeared...other message can' t remember). My father tested the motor: PACIFIC SCIENTIFIC High Performance Motors & Drives Made in USA http://www.pacsci.com/ MODEL NUMBER PRODUCT CODE SER.NO PWM 3640-5755-7 FGP 1426 07003015999 VOLTS AMPS HP RPM DUTY 130 DC 23.2 3 - 1/2 3950 CONT FIELD CLASS AMBIENT IP ENCL. WATTS PF GROUND PM -12/40C OPEN 2611 1 CASE MET VILTSTIFT: 813-4030 (vermoedellijk stock nr. fabricant loopband) Diagnose: motor met 110 volt gelijkspanning gevoed; met houten lat op vliegwiel afgeremd bij ong. 5 ampere stroomopname staat motor bijna stil - koppel veel te laag! Vermoedellijk is het permanent magneetveld door het gebruik mettertijd verzwakt. Magnetical field to low?
3 Suggested Answers
  • 95 Answers
SOURCE: Supplier for a Tunturi T85 treadmill circuit board?
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
Posted on Sep 18, 2012
ercupa190
  • 12223 Answers
SOURCE: I have a T85 Treadmill and the running platform is stuck in the highest position. A message on the display says 'check Transmitter'. Is there anything I can do to fix it?
PLeae RUN the software calibration for troubleshooting go under the HOOD motor and read the instruction steps, or go to instr. manual in how to enter in the s.calibration and fix it.
However you can measure the input voltage elevation motor, and lube the shafte, gear, see the photo and diagram attached.
God bless you
Posted on Nov 19, 2012
Hello, My T85 does not want to move up and down
RUN the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor, and fix it.
God bless you
Aug 20, 2013 | Tunturi T85 Treadmill
Tunturi T85 data transfer error
Yoy need now lower power board
Dec 29, 2012 | Tunturi T85 Treadmill
God bless you
Nov 18, 2012 | Tunturi T85 Treadmill
Sep 14, 2012 | Tunturi T85 Treadmill
Can we use 180 vdc motor in replacenet to 260 vdc motor on our tunturi t85 thread mill?
We can sell new motors, power boards and other spare parts for Tunturi T85 ain.vari@gmail.com
Jun 28, 2012 | Tunturi T85 Treadmill
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
    Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
    LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
    The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
    Jun 11, 2010 | Tunturi T30 Programmable Treadmill
    Treadmill Tunturi T 20 keeps inclining upward by itself
    Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
    May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
    Tunturi T85 Treadmill Logo
    231 people viewed this question
    Top Tunturi Exercise & Fitness Experts
    gbob59
    Jeremiah Meyer
    Jeremiah Meyer
    Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
