Question about Singer 3116 Simple
How do I make a buttonhole on Singer model 9224
SOURCE: buttonholer on Singer 2639 sewing straight ahead
Also make sure that you pulled the buttonholer lever down and pushed it back (it's on the left side of the presser foot) ... the machine won't make the forward and backward motions to form the buttonhole without it.
Posted on Aug 06, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 139 Answers
SOURCE: SINGER 7422 28 STITCH 2 BUTTONHOLE INSTRUCTION MANUAL
http://www.singerco.com/accessories/manuals.html
Posted on Apr 07, 2010
SOURCE: I have a Singer model 9910 and am not able to make
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
Posted on Oct 08, 2010
Tally Girl
  • 1133 Answers
SOURCE: My Singer 2950 buttonhol-er stitches only one side
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Posted on Nov 02, 2011
Testimonial: "Thank you so much! I actually found out (quite by mistake) exactly what you have shared--on this site. What a helpful site. The lever had not been pulled down all the way. It seems to have two "stops" and when I pulled it all the way down to the second stop, all was well. Thank you again!"
Buttonholes singer 9015
Singer has a free download for a model 9015 manual. It covers setting up for sewing buttonholes, and making adjustments.
http://www.singerco.com/uploads/download/436_5_8_10_16_22_dial.pdf
Oct 21, 2017 | Singer Sewing Machines
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
Singer futura ce 200 buttonhole lever not stopping where it should
the buttonhole lever may need to be checked to see if there is something wrong with it
Apr 01, 2016 | Singer CE-200 Quantum Futura Computerized...
Need instructions for Singer buttonhole attachment 103233.
I found a manual for several Singer Buttonholers here: http://ismacs.net/singer_sewing_machine_company/manuals/singer-sewing-machine-manuals.html . I'm not sure of the part number for the Professional Buttonholer Model, which looks like the one for my Singer Touch & Sew. Mine is part #161829 (if I read the box correctly).
I hope these help.
Feb 06, 2016 | Singer Sewing Machines
Singer 7258 will not sew automatic buttonholes. The needle goes up and down, but that's all. The buttonhole lever is down, so that's not it. Please help.
if the sewing machine is set on the buttonhole setting then it's
possible that the sewing machine motherboard has a problem.
or a part could be damaged, the machine may need some type
of adjustment.
Dec 01, 2012 | Singer 7258 Sewing Machine
I have a Singer model 9910 and am not able to make a buttonhole on the setting for #61. The buttonhole seems to be inserted properly and the foot is lowered but the machine just beeps and will not sew.
May 15, 2010 | Singer Quantum 9910 Computerized Sewing...
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Singer 3116 Simple Logo
19 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
