Question about Westinghouse Televison & Video
PEDESTAL style#EW40T4FW
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Apr 18, 2015 | LG Washing Machines
I had a holmes HPF 650 MCU outdoor pedestal fan which worked great for five years and then abruptly stopped working. Rather than repair it, I tossed it out thinking I could purchase another one. ...
Hi Bill.
Holmes makes a very good fan.
You can buy a new one here:
http://www.overstock.com/Home-Garden/Holmes-HPF650-U-Oscillating-3-speed-Stand-Fan/3473589/product.html
Good luck from Detroit, MI.
Sep 18, 2011 | Holmes Products (HPF650MCU) Stand...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
I have Galaxy type 9 Style N pedestal fan that is locked up. I need a manual so that I remove the motor housing and inspect the unit to determine the problem.
before you take it to bits try a splosh of wd40 in the motor the bearings are likely to be sezed up thats all and wd40 wont hurt the motor anyhow,,you could soak the hole fan and motor in it if you wonted to,,,it wont hurt it at all,,,
Aug 11, 2010 | Dryers
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
How do I remove it
Lift the machine off. There are no securing bolts on the new style.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove the pedestal from whirlpool duet washer and dryer
The unit simply sets on top of the pedistal on the newer style.
Lift off the unit to separate the 2.
Nov 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Jan 01, 2009 | Patton (HASF1016UC) Stand (Pedestal) Fan
Electrical Contact material
most contacts with silver colouring is a silver alloy the root cause of arcing and burnt out points might be a wrong value capacitor
Oct 05, 2008 | GE WSXH208A Front Load Washer
Vibrates badly
did you remove the shipping braces when you installed it you can find their location in your owners manuel under installation
Mar 28, 2008 | LG WM-2277HW Front Load Washer
Televison & Video Logo
12 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
