Question about General Electric 100Amp 3-pole circuit breaker
Wire GE shunt trip breaker 125 amp 3 phase to eos
2 Suggested Answers
SOURCE: wantneed diagram for G.E. TL412CP sub panel
Do you have any wiring in the panel already? The green or bare copper wires will go the ground bar which will be screwed directly on to the inside of the box. The ground bar will be in contact with the box. If the mains are wired into the main lugs the main ground will have a green stripe or it may be bare multi strand aluminum. All ground wires go under screws individually on the ground bar. The white wires go onto the neutral bar. The neutral bar will be affixed to the inside of the box on plastic isolators that do not allow contact with the metal panel. The main neutral will have a white stripe or it may be solid white. The neutrals will go under individual screws. The hot wires will now go under the screws of the breakers. All screws must be tightned firmly but not as tight as you possibly can. The hots will be black or red. The wires should alternate black, red, black, red. Begin with black on the top two breakers the one left and the one on the right. The hot wires will be either black or red.
Posted on Mar 03, 2012
What voltage and amperage is required to trip a shunt trip unit
The circuit breaker will have a shunt trip voltage & current ratings, a variable current selector knob, etc. - based on the type breaker (Catelog number). Here is a link to images of C-H shunt trip devices and circuit breakers
cutler hammer shunt trip circuit breakers parts Google Search If you can provide the catelog or model number - I 'll be able to provide add'l help.
Mar 11, 2014 | Eaton Electrical Supplies
On a 63 amp three phase circuit breaker. is that 63 amps per pase or total over the three phases.
Total amp rating of breaker.
Total amp draw across all three hot wires.
If one leg is weak or gets hot enough to exceed heat rating of breaker, the breaker will trip all 3 poles.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html#panel
http://www.electriciantalk.com/f5/
Mar 16, 2013 | Electrical Supplies
I have a square D breaker with shunt trip. The breaker keeps tripping so how do I check the breaker?
A shunt trip breaker operation.
It works just like a normal circuit breaker with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker.
So what is wired to the shunt that is not letting the breaker reset?
Read more: http://wiki.answers.com/Q/How_does_a_shunt_trip_breaker_work#ixzz1EXNCP5r0
Feb 20, 2011 | Square D Qob120 Circuit Breaker With Shunt...
Have just installed a 1P 20-QOB shunt trip breaker in the panel. Landed the 120 v circuit back on the breaker ...have a hot(common) from the relay and a return leg ....just not sure if i put the common...
Treat the shunt trip as if it were a switch. The neutral (usually white wire) on the shunt trip connects to the neutral busbar. The other (usually black) wire is the "switched leg", so to speak. The hot that goes out to the relay comes off a _separate_ breaker. The return from the relay connects to the black "switched leg" on the shunt tip. Most shunt trips have 2 wires coming off the shunt trip, a white and a black. If your breaker has contacts instead of wires coming off the shunt trip, the concept is still the same.
Feb 12, 2011 | Square D Qob120 Circuit Breaker With Shunt...
Can tree limbs touching/rubbing against the wires coming from the utility pole cause the 100 Amp Main circuit breaker to trip????
yes,if it has worn the insulation through on one or more of the hot phase conductors to the neutral phase wire,but also check the neutral busbar in the breaker panel for a high resistance connection as this will also trip the main breaker
Jun 06, 2010 | Gb Electrical 100 Amp GE Load Center
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
First & Third space in GE TPL412RP are hot, second &fourth not
This is not 3 phase power...you have two legs of 120 ...the red wire? This leg is not a voltage source therefore that wire is not going to fire up that lug ...you only need 3 wires to make this circuit and a neutral is a redundant leg for this box
Jun 28, 2009 | General Electric G.E. - INDUSTRIAL SYSTEMS...
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Jan 29, 2009 | Cutler Hammer Cutler-Hammer No.BR48L125RP...
General Electric 100Amp 3-pole circuit breaker Logo
44 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
