Question about West Bend Webalco Oil Core Electric Skillet Vintage Fry Pan Stainless
How can you tell if a skillet is 'oil core' - West Bend Webalco Oil Core Electric Skillet Vintage Fry Pan Stainless
Make a non-stick skillet non-stick again
David, If the skillet has a teflon coating and that coating is starting to break down just dump that skillet, you will never repair it and it is toxic to the kidneys. If it is cast iron then you will have to clean all the burnt food of dry the skillet, Dry it with heat and coat it with oil, flaxseed oil works well. slowly raise the temp of the skillet and hold it for about 30 mins then just let it cool.
Dry well and coat it with a little oil after each use,, same for carbon steel. The non-stick properties will improve with use.
Oct 24, 2017 | Kitchen Appliances - Others
Tip
General Tso's Tofu
Here is an amazing tofu recipe that i found online and unfortunately can\'t find the website where i copied it from. But it makes this (in my opinion) unflavored food taste like heaven.
Ingredients:
For the Tofu:
1 package of tofu
1 tbs arrowroot
3 tbs gluten-free, low-sodium tamari
1 tbs fresh ginger, grated or 1 tsp. ground
1-2 tbs canola or peanut oil
For the Sauce:
1 tbs sesame oil
1/4 cup gluten-free, low-sodium tamari
1 tbs arrowroot
3 tbs honey
2 tbs hot sauce (optional)
1 tbs canola oil or peanut oil
4-5 scallions, thinly sliced
4 cloves garlic, minced
Sesame seeds, for garnish
Instructions:
Cut the tofu into cubes. In a shallow bowl, combine the arrowroot, tamari and ginger. Whisk until smooth. Add the tofu and toss to coat.
Let the tofu marinate for at least half an hour, the longer the better.
When the tofu has marinated, heat 1 tbs of canola or peanut oil in a large skillet over medium-high heat.
Add the tofu to the skillet and cook until golden brown on all sides, about 4 minutes per side. Remove the tofu from the skillet and set aside.
Wipe out the skillet because you’re going to use it again.
In a large measuring cup or bowl, combine the sesame oil, tamari, arrowroot, ginger, honey and hot sauce, if using. Whisk until smooth. Set aside.
Heat the canola oil or peanut oil in the skillet over medium heat. Add the scallions and garlic and cook until fragrant, about 2-3 minutes.
Add the sauce to the skillet and let it cook until it thickens a bit. If it gets too thick, add some water.
Add the tofu to the skillet and toss to coat in the sauce and reheat the tofu.
Sprinkle some sesame seeds over the dish when ready to serve.
Bon Apetit!
on Oct 13, 2013 | Cooking
I lost the cord to my town craft electric skillet, haven't been able to find one, now Otis leaking oil from just sitting there
I have never hear of any one naming there electric skillet but if "Otis" is leaking oil then he has probably seen better days and it might be better to just replace him.
Apr 12, 2015 | Kitchen Appliances - Others
Need a booklet for it
I Have Oil core skillet and I want to know what kind of oil do you use in the core of the skillet? Does anyone know..............
Jan 30, 2014 | West Bend Kitchen Appliances - Others
I need a cord for a westbend regalware kitchen nutrition electric skillet
Regal Ware Consumer Service will be happy to help you. Please phone 262-626-2121, option 1 for assistance.
Dec 11, 2013 | Kitchen Nutrition West Bend Americraft...
I need a new "leg" for my society electric fry pan
You don't need anything unless the frying pan doesn't work because of the leg.
what you can do is just put an object in place of the leg it works out cheaper too
Oct 21, 2013 | Society / Regal Ware Society Regal Ware...
How should I store my cast iron skillet?
You should store it without the lid. If you leave the lid on then it is more likelt to rust. Some people even put a paper towel inside to protect against moisture. I leave a paper towel in all my pans.
Jan 16, 2013 | Home
Need a newtemeperature control plug,, model sy-192k skillet, with a built in temp. controller.The skillet model is SS120.
Please tell me where to order this control plug for this electric skillet. Thanks, Jane Royer (navigator1966@verizon.net) # 6701 control HELP
Jan 10, 2011 | All-Clad 99006 Electric Skillet
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
I have a precise heat oil skillet and need to get in touch with the company about warranty . I need a phone number for customer service
I need a replacement temperature control unit for the Precise Heat Electric Skillet, KTES2. Where can I get this?
Mar 09, 2010 | Precise Heat Kitchen Appliances - Others
West Bend Webalco Oil Core Electric Skillet Vintage Fry Pan Stainless Logo
35 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
