Calypso tv Power light on TV keeps blinking and tv won't come on
bbtoast
  • 319 Answers
SOURCE: power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Posted on Jan 05, 2008
dsacco86
  • 1077 Answers
SOURCE: power light keeps blinking green with no display
I would try leaving the TV unplugged for 30 minutes to let the TV reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
bshldn
  • 736 Answers
SOURCE: doesnt power up light on tv just blinks green
Assuming the television is out of warranty and that you can complete the repairs yourself there is a new and a recycled power unit available for purchase from Partstore.com if that turns out to be the problem. However if the unit is in warranty you would call 800-237-4277 to get the contact information for your nearest Sharp authorized service center and bring it in for repairs. When you call a representative can transfer you to a representative that can attempt to walk you through an industrial initialization of your television and then provide service center information if not successful in or out of warranty. A blinking power light could be a loose connection or loose connection to inverter and other things in addition to what was previously stated.The pattern the indicator light is blinking in is a code that indicates what the problem is.
Posted on Apr 28, 2010
  • 144 Answers
SOURCE: RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
Posted on Jun 23, 2010
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Blinking orange light
The blinking light is a symptom of power suppply trouble in this type of tv
Apr 21, 2013 | Dell W2600 26 in. LCD Television
My onn tv won't turn on the stand by blue light just keeps flashing !!! Does this mean it has gone to tv heaven ???
Often it can be as simple as bad capacitors on the power supply board, or if you cant desolder and solder replaceing the power board will usually solve a blinking power light for certain LCD tvs depending on model number but I would need your model number to further assist for your paticular situation
Dec 16, 2012 | Televison & Video
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a Panasonic model TH-42PZ80U Plasma Tv the red light keeps blinking 10 times and it won't turn on?help
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
Jul 18, 2011 | Panasonic Viera TH-42PX80U Plasma TV
When I turn the tv on it show a blue light but now the tv won't turn on and a red light keeps blinking. What should I do?
Replace the defective electrolytic caps on the power supply and/or replace power supply, check at www.partstore.com That should fix your problem.
May 31, 2011 | Proscan 32LA30Q Television
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
