Question about Bosch Washing Machines
My Bosch max 900 front loading washing machine won't rotate
My machine won't rotate the drum
barkencoa
  • 3463 Answers
SOURCE: bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
barkencoa
  • 3463 Answers
SOURCE: drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
Posted on Nov 08, 2009
barkencoa
  • 3463 Answers
SOURCE: Have a WFL2480AU Bosch Front
Most likely to be the brushes in the motor that need to be replaced, check them for wear, and if less than 4 or 5 mm long, replace them.
Posted on Nov 08, 2010
Testimonial: "Great quick response."
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
There is brown oil coming down the 2 supports for the drum so the bearings may be gone how do I replace them
Check on YouTube with your bosch bearing change demo; excellent vids there. For parts look in Fixya.
Click helped if helped
Mar 26, 2013 | Bosch WFL 2063 Front Load Washer
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
My Bosch washing machine drum does not spin at all
No, there is no rotation on the drum at all tresilla.
Jun 21, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
