Question about Weiser Lock Powerbolt 1000 Lock
Lock not functioning properly
Installed power1000and lock will open but deadbolt won't Activate to lock position
  • 71 Answers
SOURCE: powerbolt does not lock, motor operates but
your may just need a new battery. im not familiar with that model but the one i had would blink the lights when the batt was low.
Posted on Nov 18, 2010
  • 17 Answers
SOURCE: I have a keyless weiser deadbolt. Can't find any
Very common for the keypad to stop working.
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing.
You can get a replacement at the store where you bought it for free or call the Weiser support line and they will mail you one for free.
Posted on Dec 26, 2010
  • 15 Answers
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Posted on May 14, 2011
  • 963 Answers
SOURCE: I have a weiser combination
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Posted on Nov 06, 2011
  • 963 Answers
SOURCE: My Powerbolt 1000 only works
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 09, 2011
Why won't my schlage deadbolt key go to the neutral spot in the lock position to remove the key?
You likely have the lever that goes from the outside portion of the lock through the striker/bolt assembly into the inside portion rotated into an incorrect position when you insert it into the striker/bolt assembly.
Sep 18, 2014 | Locks & Locksmithing
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
I purchased a schlage lock and the deadbolt won't
Check for clearance between the deadbolt and the striker plate in the jamb
Jan 19, 2013 | Locks & Locksmithing
Key turns freely in deadbolt, but suddenly won't engage the lock
get in a locksmith ( possible ******* entry attempt damaged the tumblers)
or
replace the lock unit
Nov 20, 2017 | Locks & Locksmithing
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
The installer says the inside bolt control will be vertical in locked position on some doors and horixontal if the door swings the other way. I can't believe Taymor makes locks for only one instance ie....
A properly installed deadbolt will have the thumb turn mechanism in the horizontal position when locked and vertical position when unlocked... regardless of which way the door swings!
Your installer has it sandwiched improperly and it needs to be taken apart and the tongue inside needs to be correctly aligned.
Sep 01, 2009 | Kwikset Professional Door Lock...
Deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Jul 22, 2009 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Schlage deadbolt simply failed to unlock, with key from exterior and from inside latch. The feel was like there was no resistance. The lock is only one year old and a previous Schalge deadbolt failed after...
you can buy some "grafite" powder at lowes that is made for stiff locks, it will grease it up. if that doesnt do it the your problem may be in the plunger. might it be out of line? if so straighten it and make sure the it aligns with the strike plate on the door jamb. one of those are sure to fix it.
Apr 17, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Weiser Lock Powerbolt 1000 Lock Logo
37 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
