Question about Panasonic NN-SN960S Prestige Stainless Steel Countertop Microwave 2.2 Cu Ft, 1250 Watts
Spins when door open
When door is open, glass cooking plate spins, when door is closed it stops. Also, spins while cooking and stops when finished.
2 Suggested Answers
  • 15950 Answers
SOURCE: NN-S963BF begins operating when door is opened
The door switch is bad. https://www.partstore.com/Model/Matsushita/Panasonic/NNS963BF.aspx
This site has the most parts. See if there is a contact list so that you can ask about the switch. I dont see it listed as a stand alone item.
Posted on Nov 24, 2013
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
The glass plate of the oven is not rotating, what should I do.is it safe to run the oven like this.
The motor driving the turntable is faulty, using the oven like this will not damage the oven, the food will not be cooked evenly though. Open the door and rotate the food occasionally to ensure allround cooking, close door and continue cooking.
Sep 29, 2014 | LG Microwave Ovens
My microwave is cooking without me wanting it to
The fact that pressing CANCEL did nothing leads me to believe the controller may have failed but a failed door interlock could be a contributing factor.
Jan 08, 2014 | Kenmore Microwave Ovens
There is a beep noise every 60 seconds 24 hours/day... what can we do to stop it? microwave model JTP85WOA2WW serial # zv676667q
My microwave beeps once every minute to let me know that it has finished cooking. If I open the door, then close it, the beep stops.
Jul 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave plate turner keeps spinning even with door closed and microwave turned off
My microwave is doing this as well; It's a frigidaire model #FGMV154CLFA.
After using the microwave part (it is also convection), the light stays on in the microwave and the turner keeps turning.
And I've only used the convection part of my microwave a couple times and I'm not sure if I was successful. While trying to cook something in convection mode, I pressed convection, then pressed the temp i wanted, then convection, then keyed in the time I wanted the item to cook. The microwave started and the timer started counting down but the countdown stopped with 8 minutes left? I left it alone to see what would happen and it never finished so I restarted the process again.
PS..I've never gotten an error code
Apr 23, 2011 | Microwave Ovens
I need to know how to operate my Kenwood KGTS23 Microwave. I put it on, operate it on how I understood it, but it doesn't warm my food (it remains cold) Please where can I get a user guide/manual for...
Use a microwave safe dish and put in some water. Now open door and keep the dish on the glass plate. Close the door, select the power to be medium or high. Or choose a fast cook. Press 0 and the start button as the microwave should start up. If there is no heat after the cycle then it is possible that the magnetron, the capacitor or the fuse is open.
Jan 08, 2011 | Microwave Ovens
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Microwave JES1139WL01
Chances are spills or steam is accumulating during cooking.
After steam or spills, it's best to wipe the moisture away and even leave the door open a while to let it air out.
The "turning slowly when you open the door" you mentioned is probably normal due to door switch timing, unless you feel the door latches or door latch holes may have some grease buildup, in which case they should be cleaned.
Always be sure to hit Stop to halt cooking, and never open the door while it's cooking. That shortens the life of the door switches and can lead to erratic behavior.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 09, 2008 | Microwave Ovens
Panasonic NN-SN960S Prestige Stainless Steel Countertop Microwave 2.2 Cu Ft, 1250 Watts Logo
23 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
