Question about GE Toaster Ovens
2 1/2 yr old oven will not heat
Oven will not heat up. Broiler works.
  • 5 Answers
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Posted on Apr 07, 2008
SOURCE: need a knob for the oven broiler on a welbilt
I needed a new timer knob as weel. I contacted KitchenAid's customer satisfaction Center at 1-800-541-6390, and they sent a new one to me at no charge.
Posted on Jan 03, 2009
SOURCE: I need a manual for my toaster oven broiler
My B&D stainless appliance rusts? None of my Cuisinart's do.
Posted on Jan 04, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Posted on Jan 11, 2009
greenspan
  • 1734 Answers
SOURCE: User Manual Oster-Toaster-Oven-Broiler-6233
If manufacturer site is of no help, check here, they have the Oster 6233 manual for download.
Posted on Aug 31, 2009
Parts I need a new Broiler Rack (P/N 21432) for Toastmaster toaster oven, Model 337. Mine doesn't have the convection oven as it is an older model.
My manual has 1(800)947-3744 Mon-Fri 8:00 am to 5:30 pm CST I have purchased a broiler pan from calling them in the past; now my unit just died yesterday so need to find another.
Jul 01, 2014 | Toastmaster 337 Toaster Oven with...
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Broiler doesn't work: the upper coils do not light up in any sett
try and try to test the broiler..if it does not really work,look for someone who can fix it
Feb 08, 2010 | Euro-Pro EuroPro 6Slice Toaster Oven with...
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Cuisinart: toaster part of toaser broiler oven does not work
Definitely a defect - return to store if possible, or call Cuisinart - it has a 3-year warranty.
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart TOB30BW Toaster Oven with...
Toastmaster deluxe oven broiler
I bought a Toastmaster Deluxe Oven Broiler #5268 is it possible to get a instruction manual online?
Aug 08, 2008 | Toastmaster 328 Toaster Oven with...
Need a knob for the oven broiler on a welbilt
Jul 13, 2008 | Toaster Ovens
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Toaster Ovens Logo
26 people viewed this question
Top GE Toaster Ovens Experts
Mack Baxter
Tom Chichester
Bill Boyd
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
