Question about Uniden GMR-1035-2 2-Way Radio
My Uniden walkie talkie keeps saying L very time I push a button
Very time I push a button my walkie talkie says L. What does that mean and how do I fix it?
    New Friend:
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Posted on Jan 19, 2016
  • 19 Answers
SOURCE: hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Posted on Apr 07, 2009
  • 360 Answers
SOURCE: Have no info booklet need to get rid of feed back
To select the VOX level:
1) Enter the Menu. Advance through the Menu until
the vox icon appears on the display. The current
level (OFF, 1-3) will be indicated. Level oF (OFF)
disables VOX, while levels - set the
sensitivity of the VOX circuit.
2) Press either the up arrow or down arrow key to the desired VOX
sensitivity level. Use level 1 for increased
sensitivity to voice in normally quiet
environments, and use a higher level to reduce
undesired activation in very noisy environments.
3) Exit the Menu.
Posted on Feb 27, 2009
vrc_tech
  • 109 Answers
SOURCE: walkie talkie problem
That would depend on what is wrong with the radio(s) Most GMR radios are through away's. The average bench time for a repair on a single radio is anywhere from $70 - $100 dollars and thats not including parts. Some manufactuers have a flate rate charge to repair thier product. you might try that avenue.
Patrick
Posted on Nov 14, 2008
Goofguyster
  • 379 Answers
SOURCE: walkie talkie wont communicate
um if it dont transmit then take it apart if you know how to or
let me see it
i can fix eny walkie talkie
Posted on Sep 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: I took out the rechargeable batteries (replaced
Press the channel/scan up or down arrow key to change3 the channel on either radio. Need the operating instructions? You can download/print them here:
http://www.banoggle.com/Products/Uniden/manuals/GMR-325-2om.pdf
Bill B
Posted on Aug 06, 2010
What does tx mean on Wilkie talkies
TX means to "Transmit" or to broadcast from your walkie talkie.
May 05, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
Unlock walkie talkie
Press and hold the call button until the "L" goes away.
Jan 18, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
We have Motorola T4500 walkie talkies. One of the units keep searching and has a z in the upper right hand corner. How do I turn that off?
The Z means the radio is scanning some or all of the channels that have been programmed into it. One of the buttons on the radio should stop the scanning. The button is usually the same one that starts the scanning, and pushing it a second time will stop the operation.
Mar 19, 2011 | Motorola Walkie Talkie 2-Way Radio
How do I change channels on a uniden walkie talkie
Press the channel-up/down buttons. See the items marked 3 and 4 on the illustration in this manual.
Mar 11, 2011 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
I bought a used pair of 21-1936a walkie talkies. I'm looking for a manuel on them but Radio Shack's website keeps saying the part number is in correct. Can you help me?
The 21-1936a was made for Radio Shack by Uniden and is identical to the Uniden GMR1038-2
The Uniden version of the manual is available HERE
Sep 12, 2010 | Radio Shack 21-1926
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
Voice activation
The Motorola T-5000R does not have VOX capabilties. Page 23 in the manual explains this.
Here is the Link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
HiTech Wireless
Mar 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Uniden GMR-1035-2 2-Way Radio Logo
253 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
