Question about Amana ALW480DA Top Load Washer
The lock light stays on after flashing for a minute but the lid doesnt stay locked and it wont do anything
3 Suggested Answers
  • 43118 Answers
SOURCE: how do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Posted on Feb 18, 2013
  • 12962 Answers
SOURCE: I have a Amana top loader washer how do bypass the lid lock so it can wash?..It fill with water then the lid light just blinks because it doesnt lock.
Locate the switch by the lid and simply connect a wire between the two wires going to it to affect a bypass.
Posted on Nov 01, 2015
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Blinking lid locked light and green sensor light on machine won't start cycle
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Dec 01, 2017 | Maytag Centennial MTW5800TW Top Load...
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
Washer will not start. Start button flashes but lid is not locked
If the lid lock light is flashing, that is an error. If the lid doesnt lock it won't do anything. There is a diagnostic test that you could do to prove it if you are good with electronics and ohm meters. Most tecks would probably tell you to replace the lid lock assembly. That is probably the cheapest part. The only problem is that without the diagnostis test it could be somthing else. But first check to see that the wire that comes from the lock is securely plugged into the control board.
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Amana ALW480DA Top Load Washer Logo
22 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
