Question about Furniture
Remote is in lock position and the chair is up.
Hi, my mother's mobility scooter won't work. The power button flashes constantly. Any ideas how I can fix it?
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 Power Wheelchair Break LeversMPV5 – The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
FWD and XHD power chair break releaseTEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads “Drive” and “Push”. To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
Apr 14, 2016 | Health & Beauty
The chair will not hold it height after raising. Is there an adjustment that can be made to hold the desired height
Gas lift chairs are made to automatically lock in the position they have been raised to, sounds like your chair is faulty.
Jan 29, 2016 | Timberland Chippewa Mens 8 Inch Tan Rodeo...
My shoprider fpc is flashing 6flash 2sec. off 6 again DL5.2i controller can anyone tell me how to find the codes or tell me what this one means.
A 6 blink means the motors are in free wheel position. Turn chair off put freewheel levers in the locked position. You should not be able to push the chair when the motors are engaged. Leave the levers locked then turn the chair on again. If that does not work the motor/s could be unplugged.
Aug 12, 2015 | Shoprider Health & Beauty
Why wont my office chair go down when my 11 year old sits on it but it will go up
Maybe it has something to do with his/her weight. Or have the chair not been locked to stay in one stationary position?
Mar 24, 2015 | Furniture
How to release a telescoping office chair
The information on this web page may be helpful. If the height adjustment lever is working fine then best to replace the gas lift cylinder. Help My Office Chair Keeps Sinking
Aug 19, 2014 | Furniture
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Forgot how to unlock power chair
This is the procedure to unlock the controller on a Pride Jazzy:
Locking/Unlocking the VSI
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Jun 30, 2012 | Pride Jazzy Select 6 Indoor Power...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
While charging batteries in what position do the levers for locking the chairs wheels go
You don't need to "lock" anything. While charging, the joystick is locked out already.
Apr 30, 2010 | Jet 3 Ultra Power Chair
Furniture Logo
62 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
