THE BASE SCREEN IS BLINKING AND ON THE SCREEN IT SAY ERROR MESSAGE #3. I WOULD LIKE TO KNOW HOW TO RESET IT OR WHAT TO DO TO SOLVE THE PROBLEM
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: PANASONIC KX-TG2258 E3 ERROR CODE
this did not work for me, I had to try several times and with the play button not the stop button, but thank you it gave me hope, and with sucsess, thank vary much
SOURCE: Panasonic KX-T7730- assigning speed dialing/one
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
SOURCE: panasonic phone KX-TG4500 base not turning on
I could tell the base unit was about to go a few days ago. Have had the phone for years with intermittent problems but it has been for quite awhile now. However, the screen on the unit started to blink a bit a few days ago. Had a feeling it was about to go but the phone kept working until this morning when it suddenly dies. After reading that changeing the cord might work, I replace the unit power cord with one from my handset and the phone is working again! Thanks for the suggestion!
