Question about Car Audio & Video
I have an Altec AC-7300 and want to use it as a two channel amp running two 6 x 9 speakers. Is this possible and what speakers would I need to do this successfully?
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Posted on Dec 29, 2008
etirbynnor
  • 655 Answers
SOURCE: 2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Posted on Apr 01, 2009
Altec ACS 45.1 is it possible to rewire speaker, 1 is no sound, other loose fitting connection?
Yes it is possible. If the speakers are good. you can replace the wire.
It is a stereo spekar I think . You need a stereo 3.5 mm jack. It has three connection point. The ground are common, the left channel is the tip, the right is the middle ring.
Feb 13, 2015 | Audio Players & Recorders
Were in providence can i find a cord to my altec lansing model:ADA215 speakers
https://www.google.com/search?q=altec+lansing+model%3AADA215+speaker+cables+&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox&channel=sb
Oct 02, 2014 | Audio Players & Recorders
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
I accidentally connected VS4121 speakers to 240V instead of 120 V
Hey i am also from india. Every speaker unit has a built in fuse unit which protects it from the over voltage. just replace that with a new fuse of same rating. if you are not sure of what rating the fuse is, consult with the electrical shops. and then ask them to give a 240v to 110 or 120v AC to AC dimmer. just use this with your speakers and they will run with no problem. but if it is a serious damage inside then you need to take it to a service center.
Dec 21, 2009 | Altec Lansing VS4121 Computer Speakers
I don't have the left and right speakers only the woofer how many wires to the computer and between speakers
The sub runs off of one jack
Each 2 other speakers run off of one jack.
One jack for every 2 speakers (1 left channel, 1 right channel) except the sub which is by itself.
Nov 25, 2009 | Altec Lansing AVS 500 Computer Speakers
Channles are going out one by one. Fixable?
Plug one of those speakers into a different channel. Like if you plugged the center or rear channel into one of the front channels and vice versa. This will narrow down if the actual speaker is bad or the channel on the amplifier inside of the sub is going bad. If the speaker is bad, you can see if AL sells replacements, if the amp is bad, a repair shop will probably charge more to fix it than what it's worth. I use a 5.1 Logitech that goes for $69 that's great. It might be time to check into another setup.
Nov 20, 2008 | Altec Lansing ADA995 Speaker
Not good sound comes frm my Altec Lansing 251i speaker
1. you first check with other media player software and use another mediaplyer software checkit this problem, if u experience the same
2. check the the dvd disc is supported the 6 channel, use another 5.1 dvd disc
Jan 04, 2008 | Audio Players & Recorders
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
