Question about Rex RX-518
Rex blind hem machine 708-2, where to get a new looper.
One of the fingers on the looper is snapped off, need replacement part, where can I get one?
I have a singer sewing machine model 1 I am wanting to order a blind stitch foot. I don't seem to be able to locate can you help me?
Hm, if you talking of a blind hem foot, this indicates that one came with the Singer One.
1 ONE Singer Sewing
It appears your machine has a snap-on foot capability, so if that is the case, a snap-on blind hem foot should work.
http://www.sewingpartsonline.com/blindhem-foot-singer-006812008.aspx
Apr 01, 2017 | Singer Sewing Machines
Rex b/s 900-pb1 wondering how heavy of a fabric will this machine stitch, particularly cordura 1000d for hiking backpack
This will depend on using the proper needle and thread on this commercial machine.
Cheers,
Embroidery Services
San Diego, CA
Jun 14, 2016 | Rex Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Need settings for Simplicity easyLock SL370 rolled hem. Machine belongs to a friend who recently moved and the instruction manual has gone missing. Thank you!
narrow 3thread seam, so remove left needle. loosen top looper tension to 3 or 2, tighten bottom looper tension to 7 or 8. thread top looper with woolly overlock thread and reduce stitch length. there is also a thread finger u need to flick back on throat or needle plate usually to make rolled hem. also move blade to right to trim less fabric as you want the fabtic to roll under inside the seam.
Apr 28, 2011 | Simplicity SL370 Mechanical Sewing Machine
Need to lock blind hem stitch end.....like single needle backtack...???is it possible
Hi, I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch. here i writing a site for you ,here you can get the manual.and easly fix the problem.
www.ifixmachines.com
hope this will be helpfull to you. please don't forget to vote me .
Good Luck
Jan 22, 2011 | Rex RX-518
Timing problem on Rex commercial blind stitch
retime your hook with relation to your needle the hook is slightly out of time causing it to "slip the loop" the hook should hold the loop until the needle retracts forming the chain
Apr 30, 2009 | Rex RX-518
How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Jan 05, 2009 | Baby Lock BL1556
REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Dec 29, 2008 | Rex RX-518
HOW TO THREAD
Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful. I have the Rex518 with the original instructional manual, but the translation into English was very poor. The MSK555 is published so you can understand the manual, and figure out how to use your machine. I too am a first time user of a blind hemming machine.
Good Luck.
May 29, 2008 | Rex RX-518
Rex RX-518 Logo
37 people viewed this question
Top Rex Sewing Machines Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Joseph Mueller
Joseph Mueller
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
