Question about Gateway Profile 5.5 PC Desktop
Gateway profile 5.5 light blinking on motherboard
3 Suggested Answers
ArcAiN6
  • 152 Answers
SOURCE: I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
Posted on May 29, 2009
  • 19 Answers
SOURCE: My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Posted on Jun 30, 2011
Jun 30, 2011 | Gateway Computers & Internet
Is there a password reset jumper pin on the motherbord......
I don't know if this will help you but you can download a load of drivers from gateway here
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2750
You can also download a guide from the same site.
Can you confirm exactly which motherboard is in the machine as the Gateway Profile 5.5 may have different boards inside. Alternatively you may need a way of accessing the system. Try running something like puppy linux which will boot from a CD and see if you can get access to the system files
Mar 04, 2011 | Gateway Profile 5.5 Motherboard
Profile 3 won't power up, green light on power brick blinks when connected, green light steady when disconnect from computer. Is the problem in the power brick or the computer itself? Thank you.
You can daignose if the problem is with power brick or computer itself, by connecting any other electorinc device from power brick. See if the green light continue to blink. Further there is a chart given on the power brick, which indicates which lights should be ON for normal state. You can also try replacing the phuse on power brick, if faulty.
Nov 19, 2009 | Gateway Profile 3 PC Desktop
The green power light is on but nothing happens,its a gatway prof
MAYBE IS A BAD MOTHERBOARD SEEN THE PROFILE 4 HAVE HISTORY OF MOTHERBOARDS GOING BAD BUT YOU CAN HAVE SORE IF YOU FIND A NEW MOTHERBOARD AND CHANGE ALL THE COMPUNETS TO THAT MOTHERBOARD AND TRY TO BOOT UP IF IT BOOT UP SOCECEFULL IS A BAD MOTHERBOARD
Oct 08, 2009 | Gateway Computers & Internet
Problems with Gateway Profile 5.5 Motherboard the fans don't work
well it not rigt way but you can plug that in another plug named chesic\system fan
Oct 04, 2009 | Gateway Profile 5.5 Motherboard
Computer will not power up. there is a green blinking light on the motherboard.
did you try to uplug and plug back up?
i had that problem.
it was a short(i know because i cause the short)
i had a old motherboard dell celeron 2.0ghz and i just was bored and started touching metal to metal and it started to blink so check your motherboard
May 22, 2009 | HP Pavilion a350n PC Desktop
Washed out monitor when viewing most web pages
exchange your dell monitor to gateway monitor.If the monitor from dell showed the same problem when you connect it to gateway. you must install video card driver. and if the monitor from gateway showed the same problem when you connect it to dell adjust your contrast to full and the brightness to 50% and adjust the colors to 100%
May 13, 2009 | Gateway Profile 5 PC Desktop
Profile 5.5 during startup screen goes blank
If the video card is an "onboard type" Is is not easy to replace.If you have a seperate video card, you may replace it with a like type, PCI, AGP,PCIe,etc. or if you computer has an open slot a video card can be added and turn off the "onboard video" in start up screen BIOS .    Since this is a GATEWAY(I do not know the model) computer you also always have the option of a complete restore . Below is their website to download al the info:
Dec 29, 2008 | Gateway Profile 5.5 PC Desktop
LG LM190E05 (SL)(01)
Gateway has multiple part numbers for the LCD inverter board. Part numbers V01216400103, V01216400104, and V01216400105 are for the Profile 5 and 5.5 series with a 15" monitor. Part number V01316500104 and maybe others are installed in Profile 5 and 5.5 with 17" and 19" monitors. Also the LG part number for the 19" monitor provided in Gateway literature is LM190E02-A4. There is no mention of the LM190E05 SL in the product specs I have seen. Gateway does make special purpose runs and does change components without much much notice though. The definitive source of exact information is Gateway Tech Support. It may cost you a couple of bucks to get answers, but the value added to your system with a 19" vs. 15" screen to say nothing of the viewing comfort should far outweigh the cost of accurate information. Good luck with your upgrade. Please keep me posted on whatever you try be it successful or not. I too have a Profile 5.5 with 15" and have been considering the larger screen upgrade. BillyB.
Oct 07, 2006 | Acer AL1916S (Silver, Black) (Black,...
Gateway Profile 5.5 PC Desktop Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
